September 13, 2008 at 10:36 am #105828brunopitchParticipant
I'm using a Roland FC200 midi foot controller to change programs,
that's ok, but when i use the FC200 expression pedal, this causes an Eclipse program change !(My OS number is : 3.51)
what i saw is if the expression pedal is set to channel #7, this causes a program change to number 7.
September 15, 2008 at 2:01 pm #117854IDeangelisMember
Hi Bruno
if Eclipse changes preset…it means your Roland IS sending a program change. Please check what's coming out of it and program it properly.
best
I
September 18, 2008 at 8:28 pm #117863brunopitchParticipant
ok, i captured midi datas with a software, but didn't find any program change.
Here's a list of messages (first data is the time) :13463,129:0,Control change,1,7,0
13453,129:0,Control change,1,7,4
13442,129:0,Control change,1,7,10
13432,129:0,Control change,1,7,15
13423,129:0,Control change,1,7,19
13411,129:0,Control change,1,7,25
13402,129:0,Control change,1,7,32
13402,129:0,Control change,1,7,41
13392,129:0,Control change,1,7,54
13380,129:0,Control change,1,7,71
13371,129:0,Control change,1,7,89
13361,129:0,Control change,1,7,106
13350,129:0,Control change,1,7,118
13165,129:0,Control change,1,7,127
13156,129:0,Control change,1,7,119
13146,129:0,Control change,1,7,111
13135,129:0,Control change,1,7,102
13125,129:0,Control change,1,7,93
13116,129:0,Control change,1,7,82
13116,129:0,Control change,1,7,71
13104,129:0,Control change,1,7,59
13094,129:0,Control change,1,7,48
13085,129:0,Control change,1,7,37
13073,129:0,Control change,1,7,27
13064,129:0,Control change,1,7,17
13054,129:0,Control change,1,7,9
12204,129:0,Control change,1,7,0
12194,129:0,Control change,1,7,8
12182,129:0,Control change,1,7,13
12173,129:0,Control change,1,7,20
12163,129:0,Control change,1,7,26
12152,129:0,Control change,1,7,32
12142,129:0,Control change,1,7,38
12132,129:0,Control change,1,7,45
12121,129:0,Control change,1,7,52
12111,129:0,Control change,1,7,62
12102,129:0,Control change,1,7,76
12090,129:0,Control change,1,7,92
12081,129:0,Control change,1,7,108
12081,129:0,Control change,1,7,122
11804,129:0,Control change,1,7,127
11795,129:0,Control change,1,7,123
11783,129:0,Control change,1,7,113
11773,129:0,Control change,1,7,104
11773,129:0,Control change,1,7,92
11764,129:0,Control change,1,7,79
11752,129:0,Control change,1,7,67
11743,129:0,Control change,1,7,56
11733,129:0,Control change,1,7,47
11722,129:0,Control change,1,7,39
11712,129:0,Control change,1,7,31
11702,129:0,Control change,1,7,24
11691,129:0,Control change,1,7,16
11681,129:0,Control change,1,7,10
11672,129:0,Control change,1,7,1My expression pedal works correctly with an other fx processor.
thanks
Bruno
September 19, 2008 at 5:35 pm #129017IDeangelisMember
Hi Bruno
I have tried here, same OS, sending CC #7 (Volume) to Eclipse. It doesn't load any preset. At this point I'd need a full description of what are you trying to do there, how the CC is patched/to what, etc.
You can also try to CLEAR SETUP on Eclipse to make sure it is responding correctly.
best
I
