Home › Forums › Products › Stompboxes › CC control of H90 Insert bypass / active
- This topic has 24 replies, 9 voices, and was last updated 1 week, 2 days ago by
Kubicixfactor.
April 27, 2024 at 8:35 am #181458
Hi, I’m having an issue MIDI controlling the insert active / bypass state (MIDI controller is an RJM GT16).
I can set everything up using a momentary CC that toggles the active / bypass state, but the problem is that it is literally a toggle – so eg, if I bypass the Insert whilst using one preset, if I then switch to a different preset in which I want the default to be that the insert is active, this doesn’t happen; the insert stays bypassed until I send a second momentary CC message.
Which is a massive pain – I’ve set up a noise gate as insert #1, which I use only for high gain patches, and I want it active for any patch that’s high gain. Given that noise gates, being what they are, can cut off sustain, I need to be able to bypass the gate on occasion – so the easiest way of doing that, you’d have thought, is being able to send a CC message that tells the H90 whether the insert is active or bypass. But as explained, that doesn’t work. Meaning the only option I have is to waste lots of storage in my H90 by creating duplicate programs – one version without gate, the other with.
Is this something I’m doing wrong ? Or is it a functionality issue ?
Any suggestions gratefully received. Thanks.
April 27, 2024 at 9:09 am #181459
May I have some clarification here? How are you switching presets? Are you doing it manually? Did you mean switching Programs?
April 28, 2024 at 9:59 am #181521
I’m using an RJM GT16 foot-controller to MIDI control all aspects of my rig, including calling up programs on the H90 and controlling various parameters with an expression pedal. Generally, it’s seamless and works like a charm.
However, I have a noise gate in the H90’s Insert #1, which I only want to use at certain times – invariably when I’ve switched to a high gain channel on my amp (but not, for example, when I’m on the clean channel).
So I set up MIDI CC10 to control the bypass/active state of Insert #1. But, it only acts as a momentary toggle – ie. whenever I send cc10=127 from the RJM GT16 Insert #1 will change state, whether that’s active > bypass, or bypass > active. What it isn’t is an ‘active / bypass’ selector – ie. for most MIDI controllable pedals, if you send cc10=0 (or whatever cc you’ve programmed) the pedal will switch to bypass, and if you send cc10=127 it switches to active. But not for the H90 inserts, it seems.
The reason it’s a problem for me is that right now the only option I have is to create duplicates of every Program – one with the noise gate in Insert #1, and one without. Which is a pain, partly because it’s extra work and complication, but also it means I’m eating up the H90’s memory by doubling up every program. Hence wanting to be able to simply send a CC to determine whether the noise gate / Insert #1 should or shouldn’t be active for any program.
Hope that’s clearer . Thanks.
April 29, 2024 at 1:03 pm #181653
We plan on adding the option for Insert Active and Insert Bypass MIDI CC commands in a future release. Sorry for the inconvenience.
For now, you should be able to get around this by saving your Programs with the insert either active or bypassed when appropriate.
May 3, 2024 at 5:08 am #181981
Hi, thanks for clarifying.
What you describe is what I’m currently having to do, but it’s a massive pain because (a) it makes programming more complicated (in terms of the all the different PC’s I have to program into my MIDI foot-controller), and (b) it doubles up the Programs in my H90 (one version of each Program with insert engaged, one without), which wastes a huge amount of memory.
Do you know the timeline for addressing this functionality ?
Thanks.
May 3, 2024 at 10:52 am #182007
Sorry, I do not have a timeline for this feature.
Why can’t you use the Insert CC toggle on/off instead of creating duplicate programs with the insert on/off?
May 8, 2024 at 9:27 am #182508
I can’t use the toggle on/off precisely because it’s a toggle (!).
This means that every time I send CC=127 to the H90, the Insert either switches On if it was Off, or switches Off it was On (ie. whatever state it was in as a result of the last CC message, it then switches to the other state when it next receives CC=127). CC=0 is ignored because it’s a momentary toggle (so it only responds to CC=127).
Which means I can’t program a patch on my pedalboard (an RJM Mastermind) where the Insert is set to be Off for that patch; similarly, I can’t program a patch on my pedalboard where the Insert is set to be On for that patch. Because whenever my pedalboard sends this CC toggle to the H90, it’s simply telling the Insert to switch On if it was Off, or Off it was On.
Whereas most MIDI controllable pedals will accept a command that says ‘bypass if CC=0’ and ‘active if CC=127’. In which case, I can program that CC for each patch on my pedalboard so it sends CC=127 if I want the Insert active, or sends cc=0 if I want the Insert bypassed. Every other MIDI controllable pedal in my rig works perfectly like this (Strymon Compradre, Boss EQ, Prostage Wahrytone and RJM Overture).
May 8, 2024 at 12:03 pm #182523
I think you’re able to save the patch in a specific insert-state, on or off. and when you send the midi-command it’ll toggle to the opposite state. So where’s the problem?
May 8, 2024 at 12:11 pm #182524
Yes, what Herr Mosa mentioned is how I would suggest handling this.
If you have a Program that you want the insert on, save that Program with the insert on. If you want the insert off, save that Program with the insert off. At times when you want the opposite state after loading the Program, use the CC to toggle the opposite state. If possible, you can program your MIDI controller to only send the high CC value for the insert active/byass action.
Otherwise, I can let you know if the momentary active/bypass feature is added in a future update.
May 8, 2024 at 12:27 pm #182525
Yes, that is more or less what I’m having to do – ie. save two versions of each Program.
But my point is that’s wasteful (it doubles up the number of Programs I need) and makes life more complicated (I have to call up different versions of the same Program depending on whether I want the Insert active or bypassed, which adds complexity to how I have to organise PC commands on my foot controller).
This is the first time I’ve come across a MIDI enabled device with this limitation, which is a shame given how incredible the H90 is in almost every other regard.
So it would be great if Eventide can bring this particular functionality in line with other companies at some point in the near future.
May 8, 2024 at 12:50 pm #182527
To clarify, I am not suggesting to save two versions of the Program. I am suggesting to save one version of the Program with the desired insert state (active or bypassed). Then, while the Program is loaded, if you would like the insert to be in the opposite state, you can use the CC toggle. It’s not necessary to save duplicate Programs just to change the insert state.
Regardless, I understand why your request is a useful feature. I just want to make sure I am communicating to you properly that there is an alternative that does not require saving duplicate Programs, it just requires using your MIDI controller a bit differently.
May 9, 2024 at 5:15 am #182542
Thanks.
February 4, 2025 at 9:02 pm #188020
I recently got a Morningstar MC6 Pro and am running into this same issue. It’s nice to be able to know for certain with visual confirmation if an insert is engaged or not when activating a Program. The MC6 has a lovely Toggle State that allows you to program 2 positions for one switch, where one represents CC=0 and the other CC=127, so that you can see the bypass state upon switch press. This seems to work with P, A, B act/bypass states (although requires a 2nd press if you send it a Bypass message when the program or preset is already bypassed.
Any update on whether or not this will be implemented?
February 5, 2025 at 9:10 am #188027
It is on the feature request list and it is something we’d like to add to a future update, but I cannot confirm any timeline for this.
August 6, 2025 at 2:51 am #191409
im having this same issue on my vp4 and it’s driving me mad! Any updates on this ?? I understand the workaround and using two programs but I really don’t like doing a PC to get my distortion pedal to kick on. It takes a split second to load the next program and I don’t notice that small gap when toggling the insert on and off within the same program. It’s a smoother transition not having to switch programs. Seems like it would be a simple fix. Algorithms “A” and “B” (M) when set to 0 it is always off and 127 is on. For Scene 1 on my vp4 I have a clean sound with reverb, scene 2 is a JHS morning glory insert I have to double press or not depending on what scene im on. And scene 3 is supposed to be my dirty Shirley stomp insert but it toggles on and off every scene I hit even though I want it to be distortion lol. It’s really confusing then my overdrives get out of sync and I can’t tell if they both are on, or just one or the other. Please help with this I’m at my whitts end and thinking of just selling this h90 and getting a second vp4. What does it take to get this update done ? Can I pay someone some money at eventide to expedite this lol ? A single little update to address this one thing would be huge for me.
August 11, 2025 at 2:14 pm #191467
The current H90 firmware does not allow for a simultaneous PC+CC message, but you may use a previous firmware version for this feature. Please email support@eventideaudio.com and we can provide the instructions for installing the correct firmware version there.
We plan on fixing this in a future update but I cannot provide a timeline for this.
July 22, 2026 at 12:54 pm #196205
Can you just tell us what version we need to have install on our H90’s for it to work? Seems like that would be quicker to mention that here instead of having to reach out to the support team?
July 22, 2026 at 1:01 pm #196206
The older pedal firmware requires an older version of the H90 Control app, and we need to share that version of the app to you view our support portal. So please contact support for help with this.
July 22, 2026 at 1:03 pm #196207
Oh ok. Thanks
July 22, 2026 at 1:03 pm #196208
Oh ok. Thanks
December 29, 2025 at 3:39 pm #194095
Hey @tbskoglund
I’m also going to add myself to this thread. I’ve been looking to replace the H9 on my fly rig and the nano POG with this single unit in duo mode. I also need the CC commands to have an on off state that can be received along with the PC changes from my Mastermind PBC 6x. While I know there’s plenty of priorities this would help a ton of users like ourselves who depend on midi to keep a pedal like this extremely funcional across tours and session work. Thank you for making incredible products.
July 22, 2026 at 1:27 pm #196211
Hello, The current H90 firmware does not allow for a simultaneous PC+CC message, but you may use a previous firmware version for this feature. Please email support@eventideaudio.com and we can provide the instructions for installing the correct firmware version there. We plan on fixing this in a future update but I cannot provide a timeline for this.
Hey friend, is this a feature you have abandoned altogether for the H90? I’d still like to be able to use the new features with the full midi control (pc +cc). Why would I have to downgrade to get that feature back? I’m just looking for clarity. While I’m a huge fan of everything you do this has kept me from having the implementation I need for it to work in my rig how I need it to function. Additionally: I’m also considering the h9 mk2 but I’m afraid of this not working on it as well.
thanks for the time and for being so helpful!
A
July 22, 2026 at 1:36 pm #196213
No, this feature hasn’t been abandoned and we plan on fixing this as soon as we can. Sorry for the inconvenience but I don’t have any further information to provide at this point.
We are aware that a number of users would like to see this implemented and we have set the priority of this accordingly.
July 22, 2026 at 3:46 pm #196217
No, this feature hasn’t been abandoned and we plan on fixing this as soon as we can. Sorry for the inconvenience but I don’t have any further information to provide at this point. We are aware that a number of users would like to see this implemented and we have set the priority of this accordingly.
Thank you so much for the reply. I’m excited for this feature to roll out soon!
October 24, 2026 at 3:14 pm #205927
Thought I’d chime in here because I’ve got a Luminite Graviton and I’m having a problem where the first press activates the bypass on the insert, but it then needs two presses to deactivate/activate it again. If there was an ACT/BYP(M) option for the inserts I think it would work fine because that’s what I’m having to configure for switch A & B.
