Home › Forums › Products › Stompboxes › CC to change pre/post on H9?
December 16, 2017 at 11:29 pm #114502edo.kamalMember
Hi, is it possible to implement a CC control (or SysEx) to change pre/post?
December 17, 2017 at 2:54 am #147894
It's possible, but since this is a preset related function, probably not a good idea.
One option for you would be to save a preset in 2 ways, one pre, one post. Then you can use a PC to select the one you want. This might work better.
December 17, 2017 at 3:26 am #147895edo.kamalMember
Thanks Nick. That’s what I was going to do until there’s a way to control via CC.
Reason for this is I’d like to maintain delay/reverb trails when I switch from pre to post.
December 17, 2017 at 1:32 pm #147897
You can do it with a sysex. In the NY I'll produce a document showing how.
December 17, 2017 at 10:49 pm #147902camnParticipant
whoa though nick- there is no way he will be able to keep reverb and delay tails with that though, right?
That hurts my head… it can’t be possible. Can it?
December 18, 2017 at 12:34 am #147903
It may end up hurting my head as well.
With a suitable sysex, you can access lots of internal parameters. We're usually disinclined to publicise this, because it is too difficult for most people, and we're worried that our staff will spend all of their time helping people with it.
But, it seems worth a try, with the warning that it is is for experts only. Probably, the fact that generating user defined sysex is beyond most pedalboards, will limit it to experts only.
December 18, 2017 at 5:17 am #147904camnParticipant
Ha I take it back. I figured the routing switch itself would kill the tails, but if I switch in the Control app they stay. Maybe it WILL work!
