Chaining Stompboxes Together Question
Home › Forums › Products › Stompboxes › Chaining Stompboxes Together Question
    • #111519
      I have a Timefactor, a Pitchfactor, and Space reverb. I have them connected together via midi cable and the Pitchfactor is the master controller..  I was wondering if there is a way to change presets and have one of them change but be in bypass mode. Trying to go for seamless transitions between songs… So I would like the Timefactor and Space to be in the correct presets and ACTIVE, but the Pitchfactor also in the correct preset but BYPASSED (It is used later on in the song).
      Also, I have a midi question, but I guess I'll save that for later. One "issue" at a time.
      Thank you!
    • #125672
      gkellum
        If you put the presets in bypass when you save them, then they will load bypassed.
