Change battery in Eclipse
Home Forums Products Rackmount Change battery in Eclipse
Viewing 6 reply threads
    • #106417
      Anyone knows what battery is in the Eclipse? I think I'll have to change it cause I get error messages every time I turn it on.
    • #119010
      Hello
      the battery you want to look for is a BR2330. You'll find a lot of CR2330. Don't use them…stay on the BR one as it's the correct part. It's a lithium round button shaped flat battery.
      all the best
      I
      P.S.: backup your presets BEFORE changing the battery!
    • #119011
      Thank you IDeangelis!
      May I suggest you put this information on your support pages also?
      Have a nice day Smile
    • #130110
      It should be added in the User Manual!
      I'll suggest that.
      best
      I
    • #130111
      Even better!
      Thanks again.
    • #130190
      It seems like its impossible to get a hand on the BR2330 where I live (in Norway). Are you shure you cannot use the CR2330, 'cause everyone tells me they're the same? What's the difference actually?
    • #130191
        To quote Panasonic-san: coin type lithium batteries are available in two types: poly-carbonmonofluoride lithium batteries (BR series) for uses that require extended reliability
        and safety, and manganese dioxide lithium batteries (CR series) for uses that require high voltage and strong load pulse characteristics.
        So essentially either can be used. CR types probably have slightly higher capacity and better current supply characteristics, so may last longer. But not by much.
