Home › Forums › Products › Stompboxes › Change Preset Name by ipad
January 14, 2015 at 3:59 pm #112247
Emanuele Sereni
ParticipantHi
I've got loaded on my H9 Max the Factory preset's library
I'm editing and building on the ipad other libraries, one for each project i need (for example one for the blues band, one for the cover band etc etc), so that when i have to go playin' i just need to load the right library in the H9 and my presets are perfects.
But at the moment i can't change the name of the presets on the ipad. I mean, i can change the name
only to the ones that are loaded in the H9, non the preset in the library of ipad. Why?
The only way i find in the manual to rename a preset is by H9 switch and Knobs, but it is referred to the presets loaded in H9
Can anyone help me?
Thanks
January 14, 2015 at 6:03 pm #127351
Emanuele Sereni
Participanti read now the differences between User preset, Factory, Stompbox preset and List preset.
So the right question could be "is it possibile to change name to a List preset"?
Or i have to change it to the corresponding User (or Factory) preset?
thanks
January 14, 2015 at 7:07 pm #127352
achaput
ModeratorHi Emanuele,
In the upper right of the Presets screen there is a tab labeled "More". If you click that you should see a "Rename Preset" option. Did you see it?
January 14, 2015 at 8:31 pm #127353
Emanuele Sereni
Participanti see it only if i'm editing an user or factory preset.
If i open a List preset, for example, that option doesn't exist. Is it right like this?
January 14, 2015 at 9:33 pm #138002
gkellum
ParticipantYou're right. We'll need to add that option. Another thing users have pointed out recently is that it's hard to change the name of presets on the H9 itself…
January 14, 2015 at 9:43 pm #138003
Emanuele Sereni
Participantexactly, not hard but it takes lot of time.
So i hope in a new release as soon as possible
Thanks for the moment
Emanuele
January 19, 2015 at 2:12 pm #138023
gkellum
ParticipantActually, if you're looking at a preset list that's stored on your iPad, if you open the preset whose name you want to change in the algorithm control screen, you can double click on the preset button to open up a dialog that will allow you to rename the preset. So, the functionality you need is there; it's just a bit hard to find.
June 11, 2015 at 9:03 am #139337
June 11, 2015 at 11:15 am #139338
gkellum
ParticipantThis is going to be better in the upcoming release of H9 Control.
