Home › Forums › Products › Stompboxes › Changing a switch in TimeFactor
January 5, 2011 at 1:29 am #107525Dr.JackleParticipant
I may have a switch that is dying due to mechanical wear. I opened up the back plate of the pedal and noticed that all the jacks are directly mounted on the PCB. If I unscrew the screws that mount the PCB and loosen the nuts holding the jacks, do I have an access to the switches, or is there something else to be done?
Thanks,
Dr.Jackle
January 5, 2011 at 4:09 pm #121323
I'm assuming that your unit is out of warranty, or you would not be doing this.
If you remove the 7 screws holding down the main board you can remove it from the unit and get access to the switches. The back panel with the jacks attached will come with it, but you have to disconnect an internal ribbon cable between the main board and the display board.
IMPORTANT – if your unit is still under warranty, opening it will void the warranty and you may be responsible for any and all future repair costs.
January 5, 2011 at 6:49 pm #121326edmiddlebrooksParticipant
I too have the switch issue. My pedal is in warranty and support told me regardless of warranty they would fix my pedal for me free of charge. It's only going to cost me a couple of days time and shipping.
I removed the seven screws to visually inspect my pedal for dirt/ debris, loose cables or other obstructions. I found that the button is soldered onto the PCB board and the footswitch button just rests on top of it. When I put the back on the footswitch works now only some of the time. I will be sending mine in for repair.
January 5, 2011 at 8:56 pm #121330Dr.JackleParticipant
Thank you for the answer. I bought the unit two years ago and don't have the original receipt anymore, so I assume it is surely out of warranty. The switch works most of the time, but I know from experience (I've had same symptoms with other pedal) it is only a matter of time that the switch has to be replaced. I haven't done anything to the pedal yet, just opened the back plate to inspect what the problem might be, and thought I'd ask for some advice before proceeding.
What kind of switch should I buy, and is there some particular things I ought to be careful with, other than the obvious, like not heating the joint too much when replacing the switch?
Thanks,
Dr.Jackle
January 5, 2011 at 9:32 pm #132467
Dr.Jackle, please email support@eventide.com with ths serial # of your unit. We will get you taken care of.
