Changing algorihtm without H9 control app
Home Forums Products Stompboxes Changing algorihtm without H9 control app
Viewing 3 reply threads
    • #112165
      dafonk
        is it possible to change the current algorithm from the h9 without using the h9 control app software ?
        I've managed to control all the parameters except changing algorihtm from my pitchfactor which i'm using as a midi controller.
        Thank you.
      • #127183
        gkellum
          If you press the preset switch on the H9 twice, it will let you select the algorithm instead of presets.
        • #127184
          dafonk
            Thank you !
          • #127185
            dafonk
              Perfect, Thank you !
