Hey guys,
I'm in a bit of a bind any help you provide would be helpful;
I've got the pitchfactor and timefactor pedals and would like to have two different sounds available on the direct access switches. Currently I can set up the board for direct access but no luck on being able to send the correct ccs to the eventide so that when sw0 is engaged Eventide 1:1 is engaged and and sw9 is engaged, Eventide 1:2. Does anyone have any experience with that that can help me out?
Also the way I have the eventides midi hookup is via a midi-solutions quadra through box and it is connected to the pedals "in"…
