May 9, 2009 at 4:38 pm #106219
me
MemberHi everybody!
I'd appreciate some help!!!
For a while my eclipse has been showing on startup :
INTERNAL MEMORY CHECKSUM ERROR.
PRESS ANY KEY TO CONTINUEso I did and everything was fine. Today I've had for the first time the following message after pressing a key:
ERROR LOADING ALGORITHM #0!.
PRESS ANY KEY TO CONTINUEAnd the unit is absolutely frozen dead!
I have no problems installing the latest operating system via Flash Card but it's no good… error loading algorithm #01!
Thanks in advance!
JAVI -
May 10, 2009 at 1:59 pm #118589
me
Memberseems like boot-installing and installing 3.51 didn't solve the problem, so i tried to install the BOOT, then install the 3.1SOFT and then instal the 3.5 soft. Now it's working but sometimes i get on startup the first "checksum" error. I'm really confused… By the way, when i installed the operating systems and was asked about clearing the setup the unit was frozen. only when i restarted i was able to get it working.
Even though it's working right now I don't feel i can rely on this machine. Any suggestions ??? -
May 11, 2009 at 12:22 pm #118593
IDeangelis
MemberHI Javi
Bad checksum errors in internal ram reported during startup imply a
corruption of the data stored in the User Preset and Setup memory. In
most cases this data corruption will not cause a problem and the error
can be cured by SETUP/Utility/fix. Serious corruption will require reformatting of this ram, with the total loss of all User Presets and Setup information.If
this problem occurs more than very rarely, it may be a sign that the
backup battery for the internal memory is failing. This battery
normally has a life of around 5 years.Please try a Clear Setup first as this is required after OS update, then proceed to Fixinternal RAM.
kind regards
I
