Chord freeze function
Home Forums Products Stompboxes Chord freeze function
Viewing 3 reply threads
    • #106396
      Zplant
      I was wondering if you can create some kind of chord freeze function with, for example, mod factor (or any other eventide pedal) so that i could 'freeze' a chord and then play over it (possible this can be achieved with Undulator effect and expression pedal)?
    • #118966
      IDeangelis
      Hello
      you could try the effect suggested in my previous post:
      MF: creating an AUTO SWELL preset
      or possibly with any Time Factor dely FX, using feedback at 100%…or its looper.
      all the best
      I
    • #118978
      Zplant
      Thanks for reply! When you play with these settings – does this algorithm work?
      1. You play a chord and 'freeze' it with an expression pedal
      2. Move a pedal (the sound does not change)
      3. Play more notes (a solo, for example) – the effect is not applied to these notes
      4. Move pedal again – the chord stops playing
    • #130081
      IDeangelis
      The functions you ask for may be possible. You should try and see what pedals and MIDI CCs can do for you.
      all the best
      I
