Chorus ala Synthex
Home Forums Products Rackmount Chorus ala Synthex
Viewing 3 reply threads
    • #106434
      ThreeFingersOfLove
      Hi all,
      I would like to get a chorus like the one in the Synthex. You can hear about it here at 00:57:
      http://www.youtube.com/watch?v=qMQWrabgrp8
      Maybe I can tweak an existing patch – but what parameters exactly? It sounds quite detuned and definitely provides for some motion to the sound – tried and didn't get close…
      Is there a way to degrade audio quality on the H-8000FW with something like a decimator?
      Anyone?
    • #119035
      IDeangelis
      That chorus is almost a vibrato. Try short delay with 4 to 8 Hz rate and use your ears for mod depth.
      To reduce bit word you can use the the NOISESHAPE module. Also check out the DITHER one.
      As an example doing bit mayhem check preset 2214 Low Res Digital.
      best
      I
    • #119043
      ThreeFingersOfLove
      Hi Italo,
      thanks for the swift reply. Can you suggest a Chorus patch as a starting point?
      Regards,
      Yannis
    • #130147
      IDeangelis
      Any one, Yannis. It's not really that complex.
      Here are some of my faves:
      -811 Allan's Chorus
      -836 PolyMod Chorus
      -855 4v Random XF Chorus
      cheers
      I
