Clear Expression pedal settings
Home Forums Products Stompboxes Clear Expression pedal settings
    • #112328
      How do I do that with the Timefactor? I've been looking over the manual and this forum, but I can't seem to find the answer. Can it be done directly in the pedal somehow? I know the my Space, for instance, you can hold down a couple buttons and it will clear the hotswitch settings. Is there a similar process in the Timefactor for the expression settings?
      Thanks,
      Jeremiah
    • #127525
      There is no global way to clear multiple expression pedal mappings – you can clear individual ones by setting the heel and toe to the same value. (See UM p.20). Don't forget to save afterwards.
