Home › Forums › Products › Stompboxes › “Click” in on/off
Hi, When I connect and disconnect my H9, it has a “click” sound inside.
This is normal??
Assuming by connect and disconnect you are referring to power, this is probably the bypass relay. The unit goes to relay bypass on power down, however the actual bypass mode is set.
