clock syncing via digital I/O
Home › Forums › Products › Rackmount › clock syncing via digital I/O
    • #111154
      Siem
        I would like to sync the H8000fw to my Lynx Hilo, via the digital I/O (the port that looks like a XLR-port). I haven't succeeded, is it possible and how do I set the H8000fw up for this with the Eventide Routing Utility?
      • #124913
          The back panel XLR AES ports can't be used as a sync source, although you can clock on internal and then use their Sample Rate Converters.
          If you truly need to lock to your Lynx, you should use one of WordClock or S/PDIF3/4 or AES11-17 as sync source inputs.
          See the User Manual for more information.
