October 9, 2009 at 2:42 pm #106520PcarboMember
I have my Eclipse connected to an Apogee Big Ben with a termination plug at a speed of 88.2. I set the Eclipse setting to Workclock 88.2. When I try to run some of the more DSP intensive programs on V4.0, they won't load. If I set the Eclipse on a lower setting, I can load those programs but I get jitter. I am running out of the digital AES ins/outs. Any suggestions as to how I can access those programs while also preserving my Big Ben connection?
October 9, 2009 at 2:50 pm #119209IDeangelisMember
Hi Pcarbo
using an external clock device (Big Ben) requires you set the Eclipse on external clock, rather than on internal. The Big Ben should clock Eclipse, not Eclipse itself.
Some programs can't run at higher than 48KHz sampling rate. The presets that show a "96" symbol in fron of their names will run at higher than 48KHz rates.
Running at 88.2 or 96KHz cuts DSP resources in half, so smaller programs only can run at such higher rates.
best
I
October 9, 2009 at 3:20 pm #119210PcarboMember
I, thats exactly what I read too. My problem is I set the Eclipse to external wordclock at 88.2 and can't run the programs so then I tried setting the Eclipse to internal at lets say 48. And I then disconnected the BNC to the Big Ben, so essentially the Eclipse is clocking itself. When I do that I find that I can open all the programs but I get digital jitter. What I wonder is that by virtue of using the AES connections for audio feed I am somehow still getting an 88.2 clock from the Apogee AD and DA 16s I use. Do you think thats possible?
Peter -
October 9, 2009 at 3:26 pm #130338IDeangelisMember
how do you set Eclipse clocking when you disconnect it from Big Ben. Sorry but we need A LOT of details.
Thanks
I
October 9, 2009 at 3:28 pm #130339IDeangelisMember
wait a minute!
You are using AES. When not using Big Ben, you should make AES-EBU your clocking source, not Eclipse's internal clock.
I
