- This topic has 17 replies, 2 voices, and was last updated 11 months, 4 weeks ago by
Eventide Staff.
March 22, 2021 at 11:04 pm #116418
I’m looking into getting an H9000. I currently have an H7600.
So is the H9000 almost like having 16 H7600 (with the ability to load 16 algorithms at a time?)
Can I use each algo with a different input/output. For example, could I have all 8 adat digital inputs going to 4 different single stereo algos. And the 8 analog inputs also going to 4 different stereo algos?
I know you can have 4 stereo fx chains on the H9000, but I wasn’t sure if you could route different outputs and inputs to each algo.
-Josh -
March 22, 2021 at 11:05 pm #157498
Yes to all questions.
December 28, 2024 at 8:48 pm #187229
Hello!
I’m also upgrading to an H9000 from an H7600. Is there a way to export my H7600 patches to the H9000?
thanks!
Corey
January 2, 2025 at 9:56 am #187322
Congrats on the upgrade! Sorry, there is no direct way to do this but we may be able to help with some suggestions.
Are you talking about custom algorithms you have built with VSig to run on the H7600? Or are you talking about factory algorithms that you have edited and saved new settings for?
January 2, 2025 at 8:42 pm #187372
Hi Thanks for your response!
My patches are just factory algorithms that I have edited and saved new settings for.
Any suggestions would help.
Thanks so much!
January 3, 2025 at 9:43 am #187389
Depending on how many presets you’d like to convert, I think the easiest way would be to recreate them on the H9000 by loading the algorithm and adjusting the presets to your liking.
If you are running the H7600 to check your presets and have a computer to run Emote, you should be able to take care of this quickly.
March 24, 2021 at 3:22 pm #157516
I’m about to pull the trigger and get one, but I had another question.
I read the SOS review and it looks like the converters are better than what I’m using going into the adat in of my prism titan. Can I route any input to any output and use a few channels as just AD conversion? For example, can I run a preamp into the analog line input and route it straight to an adat output? And still have 8 channels to use for fx processing, maybe using usb and setting up an aggregate device?
March 24, 2021 at 4:23 pm #157518
Yes.The H9000 can function as patch-bay taking advantage of its pristine converters for its analog inputs, then routing them to any outputs. Keep in mind, USB, Pro Tools, MADI, Dante, and analog outputs are ALWAYS available (Dante, MADI, & Pro Tools require expansion cards). You can also have one of five digital output formats available as well – ADAT, AES3 DB25, AES3 XLR, SPDIF RCA, and SPDIF Optical.
April 15, 2021 at 5:00 pm #157653
Well, I just got my H9000. I’m trying to get everything setup and had a question. Does the unit work out of the box like a standard a/d/a converter. For example can I simply plug in an analog signal into the db25 channel 1 and it will come out the adat digital channel 1? Or do I have to manually route it to work this way?
Thanks,
Josh
April 15, 2021 at 10:50 pm #157656
There’s no problem if you leave it on and choose to power it on/off from a conditioner.
March 22, 2021 at 11:39 pm #157501joecozzi wrote:Yes to all questions.
That is AWESOME! I can’t even fathom having the equivalent of 16 h7600s just sitting there. That’s a lot of power.
Thanks for answering my question!
April 15, 2021 at 5:40 pm #157654jerzythepeddler wrote:Does the unit work out of the box like a standard a/d/a converter. For example can I simply plug in an analog signal into the db25 channel 1 and it will come out the adat digital channel 1? Or do I have to manually route it to work this way?
Congrats on your new unit, Josh! All connections have to be manually routed. If you press the FX CHAINS button, you will see a a “Direct I/O” soft button option (bottom left grey button). Here, you will be able to create direct audio pathways between physical audio inputs and physical audio outputs. In fact, you can even mult signal from one input to various outputs.
I recommend using Emote to more easily do this.
Congratulations! Lucky you, I’m sitting here and waiting for mine to eventually ship since early January 2021…
Thanks,
Josh
Save your sanity and read the Emote manual and use that. All the I/O is drag and drop. Really simple once you wrap your head around it.
April 15, 2021 at 10:44 pm #157655joecozzi wrote:jerzythepeddler wrote:Does the unit work out of the box like a standard a/d/a converter. For example can I simply plug in an analog signal into the db25 channel 1 and it will come out the adat digital channel 1? Or do I have to manually route it to work this way?
Congrats on your new unit, Josh! All connections have to be manually routed. If you press the FX CHAINS button, you will see a a “Direct I/O” soft button option (bottom left grey button). Here, you will be able to create direct audio pathways between physical audio inputs and physical audio outputs. In fact, you can even mult signal from one input to various outputs. I recommend using Emote to more easily do this.
Thanks! I figured out the Direct I/O after playing around with it. i can’t believe how deep this thing is. And the converters sound incredible.
Do you recommend leaving the unit on most of the time, since it has a long start up? Also, is there any reason to turn it off from the front button instead of a power conditioner in a rack?
April 16, 2021 at 6:33 pm #157663Matthias Adloff wrote:jerzythepeddler wrote:
Thanks! Hopefully your will come sooner than that.
I seriously can’t believe this thing can do all that it can. I can route anything to anywhere. The flexibility is absolutely bonkers.
I’m aware of that the H9000 is the best multi FX gear the world has to offer. If you have unlimited time and don’t care about using warez, you can probably achieve almost the same results with plugins for no money. If you buy every plugin you need to replace the H9000, you will pay more in the end. If you have unlimited time, you probably never get your work done.
But: If you need to get your work done and you are serious, getting the H9000 is a no-brainer. I envy you today 🙂
April 17, 2021 at 12:29 am #157666Matthias Adloff wrote:jerzythepeddler wrote:
In a case study of one, I cannot get the SP2016 plugin to sit as well as the H9000 version. I dont know why, I know its supposed to be the same. It’s just different.
