Compact MIDI pedal for H9?
Home Forums Products Stompboxes Compact MIDI pedal for H9?
    • #115125
      4_cuerdas
      Hello fellow H9-ers :-),
      Is it possible to activate/deactivate the repeat function in a delay patch with a midi switch pedal? If this is the case can somebody recommend me the smallest midi switch pedal that can help me achieve what I want?
      Another thing I want to do with the same midi pedal is to access the restart sequence button in a arpeggiator patch, is that possible?
      Can somebody point me in the right direction?
      Cheers!
    • #150877
      bohan
      4_cuerdas wrote:
      Hello fellow H9-ers :-), Is it possible to activate/deactivate the repeat function in a delay patch with a midi switch pedal? If this is the case can somebody recommend me the smallest midi switch pedal that can help me achieve what I want? Another thing I want to do with the same midi pedal is to access the restart sequence button in a harpeggiator patch, is that possible? Can somebody point me in the right direction? Cheers!
      There are many options you can choose from. You don't even need a MIDI device to do this. You may get an aux switch to do what you want (something like this: https://store.eventideaudio.com/collections/accessories/products/ox-9 ). You can assign the Performance switch (aka Middle footswitch) to an aux switch to achieve the REPEAT and RESTART function in delay and Harpeggiator algorithms.
      If you do want a small MIDI controller, here I listed some I heard are good:
      http://www.freethetone.com/en/products/system/mc3.html
      https://www.disasterareaamps.com/shop/dmc-3xl-gen3
      http://www.one-control.com/gecko-mkiii-midi-switcher.html
      You would need to assign a MIDI CC message to the Performance switch (aka Middle footswitch). You can do this easily in H9 Control app in Pedal Settings -> MIDI Settings -> Assign MIDI CC messages to pedal functions
      • #150883
        4_cuerdas
        Exactly! OSX9 it is!, I found that out a couple of hours ago by reading the manual :-). Thanks for your reply!
        Cheers 🙂
    • #150882
      mistercharlie
      I have this, and it’s great:
      https://www.morningstarfx.com/
