Compatibility with FL Studio
Home Forums Products Plug-Ins Compatibility with FL Studio
Viewing 4 reply threads
    • #111696
      rvag
      I was able to load the Ultra channel plugin but only on the master channel loading it more than once causes an unhandled exception access violation if trying to load the VST more than one instance, is there an incompatibility with FL studio or is there a way to get the 2 to play nice, Thank you!
    • #126104
      DGillespie
      Hi rvag,
      We don't usually test against FL studio, but I'll look into it.
      What OS are you on?
      Thank You,
      Dan
    • #126105
      tlongabaugh
      Hi rvag-
      Could you let me know what OS and what version of FL Studio you are using? I'll try to reproduce the issue.
      Tom Longabaugh
      Eventide
    • #126107
      ataboada
      Hi rvag,
      I am currently trying to reproduce your issue in FL Studio, but I don't seem to be getting the access violation upon loading multiple instances of UltraChannel.  Would you mind providing me some more information about your setup?  (OS, version of FL Studio, etc)
      Thanks,
      Anthony
    • #126108
      rvag
      Its windows 7 64 I also found a workaround that possibly works . the mixer channel needs to be muted prior to adding it. Maybe there's an easier workaround but this seems to work for now
