Trying to make sense of the various routing capabilities of MXLNK. I'd like to connect a mic (phantom powered condenser) to the "MIC / LINE IN" XLR input, then pick on some effects via an H9 stompbox through the effects loop of MXLNK on the fly and then send it all out to a guitar amp which is connected with a 1/4 jack on the "TO AMP" output. Will that work? Or does microphone input only leave through the "DI / LINE OUT"?
I was not able to extract that information from the various routing diagrams on the webpage as there's either a mic connected and the di/line out, or a mic and an instrument connected – but then going out through both amp and di/line outs.
Now that makes sense. Way easier using MixingLink than the AUX send of a mixing console then. Saves two DI boxes I guess.
