Connect Eventide Eclipse to Rme Fireface 800 ?
Home Forums Products Rackmount Connect Eventide Eclipse to Rme Fireface 800 ?
    • #106247
      Lars
      Hello everyone i?m recording here in Sweden with Cubase sx 3 and Fireface 800 .
      I?m not technician cant every term , but how you folks connect your soundcard to Eclipse?
       i?ve tried S/dif send from FF and IN on Eclipse it?s Good but when i tried SENDING TOGETHER  OUT/ Eclipse and IN/FF 800 then i get FEEDBACK?
       I?ve tried both Pro annd Csn i have no idea what diffrence is ?
      Maybe some of you do have same issue or same soundcard Can anyone help me ?
      Thx  Very Much
    • #118664
      IDeangelis
       Hi Lars
      very likely your audio routing in Cubase is sending AND receiving signal to and from Eclipse at the same time, thus creating a loop that runs away to feedback. You should have only one way audio when you listen to it.
      all the best
      I
    • #118682
      geminimac
       Also make sure to try various patches. Some could cause feedback depending on input/output levels.
