Connections help
Home Forums Products Rackmount Connections help
    • #111234
      Hello I need help in connections i want to make cable for my eventide h7600
      i need to know whice cable and connector i need for :
      1.  Spdif ?
      2. Word clock ?
      3. Analog  ?
      And about the analog  i see in the site that
      High Level Signals ALWAYS Use the XLR Connectors
      http://web.eventide.com/kbaudio/article.php?id=099
      Will my h7600 I have used XLR for 4+ or i can use STR and i still get the 4+ ?
      ?Since  it does not appear on that list?
      And here you recommend ? Always keep balanced the cables ends connected to the Eventide XLRs I/O and unbalance the ¼" ends connected to unbalanced gear "
       Or
       In Suggested balanced cables in wiring all Eventide units as:
      balanced XLR to unbalanced ¼” jack
      So its mean that for synth or somthing that unbalanced i need to make cable balanced cable with XLR To Ts unbalanced ?
      and what   if its gear that is balanced Like my soundcard fireface 400 or virus ti  ?
      Waiting for an answer Thanks to all who helps
    • #125066
        It really sounds like you have too many questions to answer here. I would suggest that you read the manual several times, and if necessary, find a local technician who can help you. But, to try and answer a few questions:
        matanazu:
        1.  Spdif ?
        2. Word clock ?
        3. Analog  ?
        1 : RCA jack/phono  2.  BNC  3. XLR or 1/4" jack
        matanazu:
        Correct.
