Connections Jumble on Algorithm Change
Home Forums Products Rackmount Connections Jumble on Algorithm Change
Viewing 4 reply threads
    • #182532
      gustebeast
      When I swap out an algorithm it tends to mess with the block’s I/O as well as adjacent algorithm I/O. Is there code in the H9000 to “smartly” update connections on algorithm change or is this more like emergent behavior?
      https://imgur.com/a/cWkh8az
      Ideally all the connections would stay the same unless the old algorithm had more engaged inputs or outputs than the new algorithm (e.g. 8 channels going into a THRU getting swapped for a Sculpt with only 2 channels of input). In that case I’d expect it to just delete the extra connections.
    • #182534
      Thanks for reporting this issue, we are looking into a fix for this. In your example, you are switching a 2in/4out with another algorithm that has 2in/2out, and I believe that is what causes the unexpected routing to happen. If all of your algorithms are 2in/2out, for example, this should not happen.
      I’ll let you know when we have a better idea about a fix for this. Sorry for the inconvenience.
    • #182536
      gustebeast
      I tried again, this time I loaded a preset, then loaded the same preset onto the algorithm. In theory this wouldn’t change anything, but it still ends up messing with the I/O
      https://imgur.com/a/1AN5hfd
    • #182538
      Thanks for sharing this. It looks like there are some other instances that can cause the issue. Sorry I have nothing to suggest for now, but we’re looking into improving this.
    • #182539
      gustebeast
      Thanks! For now I’ll keep reassigning the connections when swapping algs, not a big deal.
