constant internet-connection to work?
Home Forums Products Rackmount constant internet-connection to work?
Viewing 3 reply threads
    • #171807
      kims
        Hi
        I did some testing on using Emote – why does Emote need constant internet-connection to work – what are it sending in and out, and to whom??
      • #171811
          Can you be more specific? An internet connection is only needed when updating your H9000.
          You can connect to Emote in a number of ways. A direct ethernet connection from your computer to the H9000 does not require internet connection. You can create an access point from the H9000 using the Wi-Fi adapter and that will not require an internet connection either.
          Otherwise, you will need to use a network (internet) connection.
          https://cdn.eventideaudio.com/manuals/h9000/2.0/content/emote/getting_started.html#connection
        • #171813
          zengomi
            Perhaps ‘network connection’?
          • #171817
            kims
              Zengomi:
              Yes sorry for my english πŸ™‚ im using cabel all the way πŸ™‚
              tbskoglund:
              I can see it in my Netlimiter pro 4, and when i unplug my internet cabel, H9000 lose connection. I have not confidence with bonjour which is apple
              Maybe its me doing something wrong so i will look into itΒ  a bit more πŸ™‚
