Control A and B parameters at the same time
Home Forums Products Stompboxes Control A and B parameters at the same time
    • #162878
      Michelle242
        Hallo, I have the Space, TimeFactor and PitchFactor and sometimes I would like to control the A and B parameters let’s say for feedback or for decay at the same time. Ideally with only one knob. This is very common practice on lots of hardware and plugins. Since I haven’t found a way to do this on the Factor/Space pedals, I would like to ask if this is possible and how. And if not I would like to request this feature.
        Thank you and greetings from Germany!
      • #162895
          You can control multiple parameters with one control using either an expression pedal or a MIDI controller. Since you have 3 stompboxes that you’d like to control this way, I would suggest a MIDI controller that would allow you to control all 3 stompboxes.
          The user manual explains how to configure these settings (Exp pedal page 26, MIDI page 44)
          https://s3.amazonaws.com/com.eventide.downloads/Product+Manuals/SpaceManual.pdf
        • #162899
          Michelle242
            Thank you very much for your answer and suggestion. Actually I have a few MIDI controllers available, but as I have limited space and I don’t like so many cables connected to the Factors, I would rather like to avoid to include additional gear, so I hoped for an “in the box” solution. But anyway, thank you!
