Home › Forums › Products › Stompboxes › Control MF with TF
March 31, 2010 at 10:51 pm #107002
zikamuricpe
MemberHi guys, I use TF for a few months and I am so happy with it that I recently purchased MF too. Since my current pedalboard is completely analog and without any MIDI controllers, I would like to know if it is possible to control TF with MF (or vice versa)? Eg could I program both devices to change/activate desired presets by actually pressing switches on just one of the two devices?
Sorry if this was already explained somewhere on this forum. Thanks in advance!
March 31, 2010 at 11:01 pm #120237
Some User Manual reading will be required, but you could set it up so that loading a preset on one unit loads an appropriate preset on the other. It will be a bit of a fiddle unless they have the same numbers.
Look for the explanations of [TX MAP] and [RX MAP]
March 31, 2010 at 11:19 pm #120238
zikamuricpe
MemberThanks for replying so quickly nickrose! I didn't find TX or RX MAP sections in User Manual, but a chapter named [XMT MAP] – Create a MIDI Program Change Transmit Map looks like what I need. Am I right, is that it?
April 1, 2010 at 2:52 pm #131420
achaput
ModeratorThere are a series of stompbox instructional videos now online, and this is one of the topics covered. Check them out here:
http://eventide.com/Home/Eventide/AudioDivision/Products/StompBoxes/StompboxTutorials.aspx
April 1, 2010 at 4:15 pm #131422
Sorry – my mistake. XMT for the sender, RCV for the receiver.
April 12, 2010 at 10:46 pm #131487
zikamuricpe
MemberThank you nickrose and achaput!
Very useful videos you made, and one of those is just about what I've asked! Great!
