October 10, 2020 at 9:04 am #116134
I see some algos have start/stop options and things like that. What are some controllers you guys are using for these functions? How are they routed in the H9000?
October 12, 2020 at 7:53 am #156006
Faderfox EC4. Class compliant, USB bus powered directly plugged into the H9000
Plug and play – select midi learn on any of the paramaters in an algo and the EC4 controls it.
Couldn’t be simpler and works like a dream!
October 15, 2020 at 11:41 pm #156032
Can I use my pre existing Akai MPD226? It’s currently usb into the computer. I never use the 4 knobs or 4 faders on it for anything. Can it serve double duty somehow??
Is there some kind of auto mapping ?
Or do you need to reassign when you switch algo ? (and can this be saved inside the algo ?) -
October 13, 2020 at 6:30 pm #156017There's no auto-mapping like Ableton's MIDI controller scrips. The Learn button just lets you press a button or move a fader or knob on a MIDI controller and have it be mapped to an Algorithm or FX Chain parameter. You have to reassign mappings when you switch algos. Mappings can not be saved within a preset, but they can be saved within an FX Chain or Session.
October 16, 2020 at 2:25 pm #156040joeydego wrote:Can I use my pre existing Akai MPD226? It’s currently usb into the computer. I never use the 4 knobs or 4 faders on it for anything. Can it serve double duty somehow??
You can plug the controller directly into the H9000 of course (via any of the USB A ports on the front or rear), but assuming you want to keep it connected to the computer, you would need a way to route the incoming MIDI from the controller to go out through the H9000 USB connection (the rear panel USB B connector that also carries USB audio). We can certainly look into it.
October 16, 2020 at 4:34 pm #156045joeydego wrote:Can I use my pre existing Akai MPD226? It’s currently usb into the computer. I never use the 4 knobs or 4 faders on it for anything. Can it serve double duty somehow??
if you use emote as a plug-in your DAW should allow you to map your controller to Functions in the plug-in.
