Home › Forums › Products › Stompboxes › Controlling expression via midi
March 12, 2020 at 11:53 pm #115822
Hi!
I thaught this would be easy but I can’t make it work. 🙂
I run my H9 with an SP-H9 expression pedal from Mission Engineering. It works perfectly and I really enjoy the dubble functionality with the footswitch on the “toe”.
I also have two Strymon effects, Big Sky and Volante. I’m trying to controle them with my SP-H9, thru the H9, via midi. Is this possible? It’s hard to find any info on how to set this up, any tip or link that kan help me succeed?
My rig is mainly controled by midi so all my gear are set to different midi channels.
Greatful for all help!
/Olle
March 13, 2020 at 3:18 am #154304ollenys wrote:
I run my H9 with an SP-H9 expression pedal from Mission Engineering. It works perfectly and I really enjoy the dubble functionality with the footswitch on the "toe".
I also have two Strymon effects, Big Sky and Volante. I'm trying to controle them with my SP-H9, thru the H9, via midi. Is this possible? It's hard to find any info on how to set this up, any tip or link that kan help me succeed?
Well there are two solutions:
1. Connect the expression pedal to your MIDI controller and have the controller send different MIDI messages to your H9, BigSky and Volante.
Or 2. Connect the expression pedal to H9, and have your H9 send out MIDI messages to your BigSky and Volante. You can set the MIDI CC output mappings in the settings menu. (Press and hold the HOTKNOB and the right footswitch, and go to the MIDI setting)
March 16, 2020 at 5:39 pm #154326
I control all my effects thru midi from a software on my iPad called Band Helper. In order to do this I have all my midi effects, Voodolab Hex and controle switcher, set to different channels.
The thing I,m trying to solve is to controle some specific effects, in different units, with my H9-exp pedal.
May 11, 2020 at 10:12 am #154829
Hi!
I thaugh I give you a little bit more background to this question. 🙂
Can a firmware adjustment substantially increase the customer value of the Eventide H9?
More and more pedals allow the user to control it via midi. No competitor can challenge the flexibility of an H9 but today, some of us build effect chains and clusters giving our pedal boards abilities close to a Bradshaw rack system.
Beside the Eventide H9 I use Strymon Volante and Big Sky. Both these pedals can receive CC# messages. Their firmware allows me to switch this on and off on a preset level.
Tweaking the H9 so it can send CC# messages on multiple midi cannels (Global) and expand the range from #99 to #127 would allow me to use the H9 as an expression pedal for all these effects. A sweep of one pedal adjusts the tone of multiple effects. How cool is that! J
I realize that primarily, the H9 is not built for this purpose. But trying to accomplish the same result with other tools seems to be almost impossible. I have been evaluating a lot of different solutions including:
· Source Audio Soundblox Reflex Universal Expression Pedal
· MisÂsion EngiÂneÂeÂring ExpresÂsioÂnator
· MIDI Solutions Pedal Controller
No one of these options would make a good solution for me. I also find it hard to loose the smooth double functionality of my H9 that I get with my Mission Engineering SP-H9-WH.
During my research I’ve found a lot of different user groups discussing this topic, so I’m not the only one trying to find a solution. I hope this information will help you to evaluate if a firmware update would be possible.
All the best!
/Olle
May 12, 2020 at 3:11 am #154838
the idea of SENDING midi on ‘OMNI’ is a little unusual. That is usually a recieve thing, I think.
That said, It would be trivial for one to make a custom MIDI expression pedal that sends multiple channels of CC data, so it can certainly be done. It is pretty niche, though. I doubt any of the majors would do it.
I might try and breadboard this out. You could probably make it for, like, $25.
May 12, 2020 at 8:34 pm #154844
Yeah it was easy.
If you wanted to make a small analog-exp-pedal to MIDI converter…it would cost $20, and you could send whatever CC on whatever channle you want to as many devices as you want, all simultaneously.
The board specified here is overkill by far, but it is what I have laying around. You could use the smallest/cheapest thing you can find, I bet.
PARTS:
Nano Board $11.00Enclosure $3.99 1590aLED $1.15 optionalpower jack $1.25Midi Jack $1.50Total $18.89CODE:
//multiple EXP pedal outs//by Cameron Newell @the.nw.enterprise, http://thenorthwestenterprise.com///Library Source https://github.com/tttapa/Control-Surface//Built for Ardruino NANO EVERY#include <Control_Surface.h> // Include the library// Instantiate a MIDI interfaceUSBDebugMIDI_Interface usbmidi(115200); // for serial monitor in ide//HardwareSerialMIDI_Interface serialmidi = {Serial1, MIDI_BAUD}; //for normal operation via 5-PIN/* Instantiate a CCPotentiometer object with multiple output channelsAssicn CC number from here:This ia an analog POT with 5v, Ground and Signal.“Expression Controller” is CC#11*/CCPotentiometer device1 = {A0, {MIDI_CC::Expression_Controller, CHANNEL_1},}; // sends C#11 on channel 1CCPotentiometer device2 = {A0, {MIDI_CC::Expression_Controller, CHANNEL_2},}; // sends C#11 on channel 2CCPotentiometer device3 = {A0, {MIDI_CC::Expression_Controller, CHANNEL_3},}; // sends C#11 on channel 3CCPotentiometer device4 = {A0, {MIDI_CC::Expression_Controller, CHANNEL_4},}; // sends C#11 on channel 4void setup() {Control_Surface.begin(); // Initialize Control Surface}void loop() {Control_Surface.loop(); // Update the Control Surface} -
March 16, 2020 at 4:24 pm #154321
So, ni success yet…
Just checking that I understand correctly: The H9 requiers that I set a specifik midi Transmit Chanel. That means that I can’t use it to controle two units with different midi channels? I would prefer to set the midi transmit channel to omni while the Volante and BigSky ignors exp-midi as long as i don’t specificly program the preset to respond.
In the XMT CC dialog I can chose the destination CC# from 1-99, wich is unfortunate when the Volante seemes to be set to receiver on CC# 100.
Is this correct or do I missunderstand something?
Appreciate your help!
/Olle
March 16, 2020 at 5:13 pm #154324ollenys wrote:The H9 requiers that I set a specifik midi Transmit Chanel. That means that I can’t use it to controle two units with different midi channels? I would prefer to set the midi transmit channel to omni while the Volante and BigSky ignors exp-midi as long as i don’t specificly program the preset to respond.
You are right.
ollenys wrote:In the XMT CC dialog I can chose the destination CC# from 1-99, wich is unfortunate when the Volante seemes to be set to receiver on CC# 100. Is this correct or do I missunderstand something?Correct. Let me talk to my colleague and see if this is something we can improve. We might implement this in the future but it would likely take sometime cause we don't update firmware very often and we just released one early this year.
March 16, 2020 at 5:28 pm #154325ollenys wrote:The H9 requiers that I set a specifik midi Transmit Chanel. That means that I can’t use it to controle two units with different midi channels? I would prefer to set the midi transmit channel to omni while the Volante and BigSky ignors exp-midi as long as i don’t specificly program the preset to respond.
Out of my curiosity, may I ask why don't you just set the receive channel of BigSky and Volante to the one that H9 is set to, if you want your H9 to control other pedals as a master device?
