Converting presets from older DSP units to H9000 format?
Home Forums Products Rackmount Converting presets from older DSP units to H9000 format?
    • #177522
      KazRemark
        I have some old exported individual DSP-7000 presets in .syx format.  Is there any way to get these converted to H9000 format?
      • #177523
        Puppeteer
          I don’t know any way of doing this. The new format is .json (from memory, or it may be xml) in a wrapper with checksums, not sysex.
          Your best bet would be to either note down settings and reprogram, or to somehow extract from the sysex, if you know the sysex byte order.
          If you can decode the sysex and work out how to generate the checksum, and the underlying algorithms are on the H9000, it would theoretically be possible to build a conversion tool, but this tool doesn’t currently exist.
