Couple questions…on modfactor
Home Forums Products Stompboxes Couple questions…on modfactor
Viewing 5 reply threads
    • #106762
      I was trying to copy someones 'octavia' setting on my modfactor
      when i set the shape to envelope on the ring mod setting, nothing happens… theres no modulation happening at all… and i cant adjust speed (sensitivity)
      the only reason i noticed was because someone else had posted that they had done it
      i have just installed the update, so im not sure if its something to do with that because i never tried envelope on the ring mod setting before
      also is it supposed to flash the name of the effect when you select a preset?
    • #119760
      c'mon… anybody?
    • #119910
      Can somebody give me an answer?
    • #119911
        It is supposed to flash the name of the effect when you select a preset. For a while, it did not (as described elsewhere on this forum) – this was a bug and is now fixed
        Don't know the answer to your ring mod query – I'll pass it on to someone who does.
      • #119912
        DGillespie
          I'm sorry for missing this post Dr. Orange.
          Suffice to say it is a bug.  I took a quick look and can't find the bug right now, however, I will find it an fix it.  We'll have to do a small point release for this.
          Thank you for finding it, and sorry for missing it.
          Dan
        • #131102
          thanks
