October 3, 2020 at 7:31 pm #116127
Is it possible at this time to create a master output within Emote that can monitor everything from all 4 FX chains? In my case I’m using the H9000R as the main interface with Ableton.
I am routing the 16 USB inputs thru the 4 FX chains to 4 output pairs, and I see that inputs can only be assigned to outputs once, blocking that output from being assigned again. So for example I cannot send the output of the 4 FX chains to a master output all within the H9000R to mix within Eventide.
Is there a workaround for this that doesn’t involve using another audio interface? I am not seeing anything that covers this in the manual, and not sure of how to use the Direct I/O feature to help with this situation.
Thanks in advance,
October 3, 2020 at 9:28 pm #155952
I use Dante instead of USB….but the setup *should* be the same.
Save the Eventide’s USB 1+2 inputs as the ‘main outputs’ of Ableton.
The other 14 inputs / outputs will be your sends. Set up a direct I/O between USB inputs 1+2 and whichever output on the Eventide you want to monitor from. An example USB 1+2 connected to Analog 1+2
This way, anything coming from your ‘main mix’ in Ableton will get routed through USB 1+2 to the Analog outputs directly.
I do it this way only using Dante…where my main outputs of Logic (output 1+2) correspond to Eventide Dante input channels 1 +2. The Dante input channels 1+2 are then routed directly to the SPDIF outputs. From the SPDIF outputs I have headphone / monitor controller setup.
Hope this helps.
Hope this helps.
This sounds great, I will try this tonight. Many thanks!
