Creating Patches for H7600 (on a mac)
Home › Forums › Products › Rackmount › Creating Patches for H7600 (on a mac)
Viewing 5 reply threads
    • #113741
      verstaerker
        i bought a used H7600 and now i like to create my own patches. I found out that VSig for windows is the program to use. As i have VMWare Fusion on my mac installed that is no problem. Making a midi device availabe in Fusion was no problem too.
        But now how to get the dbase file from the H7600? The menu-entry “Get DBase” does excatly nothing. On the H7600 i can send a “dump internal” .. vsig then shows a little spinning clock . It seems to receive some data. After some time it’s finished. And now?
      • #144542
          The GetDbase command should do something. But, if you can't make it work, the dbase is also available in the Vsig section of our Web Site
          https://www.eventideaudio.com/support/product/1462/supplements
          • #144545
            verstaerker
              that file obviously worked .. i can create patches now. But upload to the H7600 doesn’t seem to work as well.
              Or do i need to do something on the H7600 to receive a patch? Or do i need the serial connection?
              nickrose wrote:
              The GetDbase command should do something. But, if you can’t make it work, the dbase is also available in the Vsig section of our Web Site
          • #144549
              You should be able to download over serial or MIDI. Assuming they work OK with your VMWare.
              If you use serial, you will need to be sure that the baud rates etc match at both ends.
            • #144558
              verstaerker
                midi works well via VMWare … (the H7600 receives midi commands like program changes)
                i ordered now a usb-serial cable.. maybe that works
              • #144569
                  Make sure that your 7600 has the appropriate MIDI settings – for example, Sysex must be enabled, with the default ID.
                • #144577
                  verstaerker
                    i got the usb-serial adapter… that did work directly without any problems
                    i i have no idea why midi didn’t work
