Maybe somebody help me figure this out:
I have one H9 on my effects board before the amp(s). For some gigs I like to bring two amps just for the heck of it (one is a triaxis based Mesa rack already running stereo with other effect units and the other Boogie Mark IV with another H9 in the loop).
I’m splitting the signal with a Lehle Little Dual after the effects board to go to either or both amps.
It would be fun to run a few of the H9 effects in stereo with both amps. Mostly it would be mono and only going to one amp. If I connect the second output from the H9 through the Lehle (which has stereo ins and outs) I could separate those effects.
Problem is now, when I want to run normal effects in mono to just one amp – I assume the H9 will only deliver one side of the stereo signal – unless there is a clever way to use the pre/post options to program effects for true stereo in my setting or sum them back together for only one side??
