Home › Forums › Products › Stompboxes › Custom Audio Electronics MC 403
April 28, 2010 at 4:29 am #107049
konstantine3
MemberIs there any info on this latest distro for the eventides? I bought one and I am currently without current for my stompboxes… guess I jumped too soon but if there is any info on how to plug these in I would appreciate it!!!
Thank you in advance!!!!
Kon3
April 29, 2010 at 9:53 pm #120357
shood
MemberI am also waiting to hear whether the Power System is a solution for powering 'Factors
April 30, 2010 at 2:59 am #120359
konstantine3
Memberit is not.. I ended up buying a Prime power strip for 18 bucks and it works fine. I did get a BBE "Supa charger" and the CAE wi ll not work with the Stompboxes… they draw too much power being digital
May 5, 2010 at 2:59 am #120380
bobcae
MemberFYI
Despite published specs, the CAE/MXR MC403 *WILL* power the Eventide stompboxes.I have been successfully powering 2 Eventide pedals from the MC403 adjustable outs (set to 9vdc) continuously for the past 5 days. The MC403 gets a little warm, but not too warm to touch. The MC403 specs are very conservatively rated, and while the Eventides ship with 1200ma. power supplies, current draw is only around 350ma.
DO NOT TRY TO POWER THE EVENTIDE PEDALS FROM ANY OTHER OUTPUTS OTHER THAN THE HIGHER CURRENT CAPACITY ADJUSTABLE OUTPUTS (SET TO 9VDC)!!
The other alternative is a AC/DC converter box to convert the 800ma 9VAC outs to DC. This works fine as well. All that is needed is a bridge rectifier/ filter cap (2200uf/ 25V works well) combination to make this work. Granted, this is more complicated, but do-able. The only other thing to keep in mind is cable polarity. The Eventides have 2.5mm x 5.5mm pin (+) barrel connectors, and the MC 405 adjustable outs are 2.1 x 5.5mm pin (-). You can easily modify the cables that come with the MC403 for this purpose.
Bob Bradshaw/Custom Audio Electronics
May 5, 2010 at 3:08 am #120381
bobcae
MemberDespite published specs, the CAE/MXR MC403 *will* power the Eventide stompboxes from its higher current capacity adjustable outputs.
Bob Bradshaw/CAE
May 5, 2010 at 3:58 pm #131626
konstantine3
Memberthanks for the report… I got a email from CAE/MXR saying that the unit wouldn't work so I went the conventional way with the strip.
thanks for the info, because its the new hot power supply item and I am sure someone can use your info. I sure wish I had this info when we started!
kon!
May 5, 2010 at 4:01 pm #131627
konstantine3
MemberI will be sure to pass this along to my music store…
May 5, 2010 at 4:56 pm #131628
bobcae
MemberUnfortunately the Eventides came out after the MC403 specs were established. Otherwise, I would have made sure the spec supported the Eventides, because I love 'em all! Luckily, the MC403 is well "over designed" in that it CAN power the Eventides, despite the spec. This power supply went through extremely rigorous testing and safety agency approvals that took over 2 years. My guess is no other power supply on the market has gone through (and passed) such testing, which ultimately makes for a well-built, reliable product.
Bob Bradshaw/CAE
September 7, 2011 at 5:44 pm #122625
jmagers
MemberHey Bob, Thank you for your answer. I have little electrical or cable modifying skills. I was wondering if you could explain how to modify the cable to make the eventide pedal work of if there was a place you would suggest that I could buy one from?
Thanks for your help!
September 7, 2011 at 10:44 pm #133795
bobcae
MemberMC403/Eventide Power Cable
Its easy if you know how to solder. You are just "butt splicing" two cables together.
Use shrink tubing or at least electrical tape to protect and insulate the connections.
Take a power cable with black ends, and one with red ends , and cut them both in two.
Then solder the "red end cable" to the "black end cable".
At this point you can trim the length of the cable too, before soldering.
You can throw away the other 2x pieces, or make a second cable.
But here is the important part:
make sure the connections don't match, because you want a reverse polarity cable.
The MC403 is Pin (-) but the Eventide is pin(+).
You can tell by looking at the cable. There are white dashes on the insulation of one of the cable conductors, which indicates the sleeve (outer) connection.
Just make sure they don't match when you solder the ends together.
Then connect the black end to the power supply and the red end to the eventide.
Use ONLY the Adjustable outputs for powering an Eventide pedal:
Switch "Out" / Trimpot all the way clockwise.
I hope this helps…Bob Bradshaw/CAE -
August 14, 2012 at 12:51 am #134769
watermelonkid
MemberSo how do I get ahold of a cable if I have no soldering tools/skills so that I can power my Eventide Space to my MC403? Is it completely reliant on a custom cable? I checked to see if the included cables with the MC403 would fit the Space, and obviously they are a bit too narrow for the connection on the Eventide.
September 11, 2012 at 2:30 am #134849
watermelonkid
MemberNobody?
September 11, 2012 at 3:15 pm #134854
bobcae
MemberThe MC403 came out before the Eventide pedals, therefore specially cables are not part of the MC403 package.Also, published spec of both units would lead you to believe it is not possible to power Eventides, but this is not true.I power them all the time from the adjustable outs only. Set to 9vdc.You can use this cable:
