Home › Forums › Products › Stompboxes › CV control through the Aux. Switch connection?
Totally random question, Can you control the pedals through the Aux Switch using cv gate? if I used a insert cable and hook up to voltage control ports to simulation Tip, ring, tip+ring
Probably – the active range is 0 to 3V, but it has protection to allow it to work over a wider range. Best not to exceed -5V to + 5V.
Awesome thanx!
