Damaged tape trick – In full stereo ??
Home Forums Products Stompboxes Damaged tape trick – In full stereo ??
    • #106781
      Scories
      Hello. I often use the TimeFactor like this:
      MONO INPUT – TAPE ECHO – 100% WET
      DELAY A : 0ms, FEEDBACK A : 0%
      DELAY B : Xms, FEEDBACK B : X%
      MIX A/B : around 25%
      SATURATION + WOW & FLUTTER : set at high levels
      Then I get the sound of a wobbling tape (instead of the dry signal) plus a single tape echo (by adjusting the delay B and the A/B mix knob)… all this in real time!
      Can I get this trick in full stereo, whithout having the Delay A panned on the left and delay B panned on the right (because Delay A should replace the dry sound and delay B should be the stereo delay)?
      Thank you
    • #119827
      achaput
      That is a cool trick you are doing. However, to get full stereo out of both Delay A AND Delay B you would need a quad delay, and TimeFactor is a dual delay.
      It could be done with an Eventide Eclipse though.
