- This topic has 11 replies, 2 voices, and was last updated 3 years, 1 month ago by
Eventide Staff.
August 11, 2023 at 3:40 am #173067
No experience here with Dante and networks, I have a basic setup : MacMini, H9000R, RME UFX (+8 channes ADAT). So far I’ve been working with the H9k via 16 channels USB, and now adding a Dante card.
Up to now I had a single ethernet cable going from my computer to the H9k. My question: What is the cabling now with the Dante card? A second ethernet cable connecting the Dante card to the computer? With a switcher necessary? Or no change as far as cabling is concerned?
August 11, 2023 at 10:32 am #173074
Congrats on the Dante upgrade! If the H9000 is the only Dante device in your setup, you’ll want to check out Dante Virtual Soundcard: https://www.audinate.com/products/software/dante-virtual-soundcard
The Dante expansion card can work as a network switch, allowing you to still use a single ethernet cable connected directly to your computer. Connect a short cable from the H9000’s ethernet port to one of the Dante primary ports, and connect the other primary port directly to your computer. Now you can connect to Emote and also access the Dante card’s I/O.
In Dante Controller, make sure the Dante card is set to “switched” mode: https://dev.audinate.com/GA/dante-controller/userguide/webhelp/content/network_config_tab.htm
August 14, 2023 at 10:56 am #173119
August 14, 2023 at 11:07 am #173124
You’re welcome.
If you are still using the UFX with ADAT, I would suggest having the UFX be the clock source for everything like so: UFX > H9000 > Dante card
To do this, set the H9000’s clock source to ADAT, and then in Dante controller check off the “Enable Sync to External” box for the EVT-H9k device. This setting enables the Dante card to sync to the H9000’s clock.
Note that in Dante Controller, you may also have to manually set the sample rate, even if it is externally synced. Double click the EVT-H9k device, click the “Device Config” tab, and set the sample rate there.
Let me know if that works.
August 15, 2023 at 2:05 am #173152
No ADAT connected to the H9000, just USB. Problem persists.
August 15, 2023 at 10:19 am #173162
Have you double clicked on both devices in Dante Controller and confirmed that the sample rate is the same in the “Device Config” tab?
More clocking information can be found here: https://cdn.eventideaudio.com/manuals/h9000/2.0/content/expansions/dante.html
You’ll have to try a few configurations and let me know everything you have tried so we can rule out what the issue may be.
August 15, 2023 at 11:25 am #173164
Yes, EVT-H9K and MacMini are both at 48kHz
More clocking information can be found here: https://cdn.eventideaudio.com/manuals/h9000/2.0/content/expansions/dante.html You’ll have to try a few configurations and let me know everything you have tried so we can rule out what the issue may be.
When I check “Enable Sync To External” it looks like this :
August 15, 2023 at 11:32 am #173165
Have you followed the below instructions? You will need to change the H9000 clock source depending on the configuration:
To sync the H9000 to Dante, set the H9000’s clock source to “Exp A/B/C (Dante)”, and uncheck “Enable Sync To External” for the Dante card in Dante Controller.
To sync Dante to the H9000, set the H9000’s clock source to “Int {sample rate}”, and check “Enable Sync To External” for the Dante card in Dante Controller.
August 15, 2023 at 12:18 pm #173171
Yes, i exectuted these steps, but there is no change (see screenshots above)
I’m a bit confused by your term “depending on the configuration”. Shouldn’t the Dante card always be running the clock and everything else should follow?
August 15, 2023 at 12:24 pm #173172
No, the Dante card can follow the H9000, or the H9000 can follow the Dante card.
When you check “Enable Sync to External” that is telling the Dante card to follow the H9000. You must make sure the H9000’s clock is set to internal, or following another clock source that is not Dante.
If you uncheck “Enable Sync to External” that is determining that the Dante card will be the clock source. You must then set the H9000’s clock source to Dante.
August 15, 2023 at 12:39 pm #173174
I followed the instructions, both ways, but still the clock status is unchanged (see screenshot 3 above)
I really appreciate the continued support but I must say, as a musician, I find this process overwhelmingly complicated.
What can we do from here?
August 15, 2023 at 12:49 pm #173176
Yes, I understand the Dante clocking can be tricky.
I’ll send you an email and we can schedule a zoom so I can check out your settings and see if we can figure out what the issue is.
