db25 connectors H9000 doesn’t fit
Home Forums Products Rackmount db25 connectors H9000 doesn’t fit
Viewing 11 reply threads
    • #174296
      pinballmagnetic
        I recently purchased two DB25 cables for the analog inputs and outputs of the H9K. To my dismay, the two connectors are incompatible; there isn’t sufficient space to connect both inputs and outputs simultaneously. It seems as though the H9000 connectors were designed too closely together, preventing the DB25 connectors from fitting properly.
        What can be done to address this rather vexing problem?
      • #174297
        pinballmagnetic
          See image:
        • #174299
          DewiJones
          • #174300
            pinballmagnetic
              “I wouldn’t have thought about the DB25 headshell girth, and would have been pissed if I bought s set that was too fat.”
              Guess i’m the lucky dude who had to learn this the hard way, sighhh
            • #174305
              Puppeteer
                I have 2 x Hosa DB25’s connected without any problem. Maybe look at a different cable.
              • #174307
                joeydego
                  Short of returning those and getting 2 compatible cables , nothing.
                  I also have the Hosa and they fit fine.
                • #174309
                  joeydego
                    What I do find a little problematic with the DB25 port is when frequently connecting/unconnecting, the nut tends to want to keep coming off the back of the unit. Is this irregular?
                  • #174314
                    pinballmagnetic
                      Would this one fit? Can anyone confirm that?
                      https://www.thomann.de/nl/hosa_dtp_803.htm
                    • #174315
                      joeydego
                        DTP 803 is the same model number as the one I have. I can confirm that much. As long as it hasn’t changed you should be good.
                      • #174316
                        mdruk
                          Hosa DTM 805 here on both ports. Fits fine. I’d assume they all use the same DB25 connectors.
                        • #174348
                          pinballmagnetic
                            Thanks all, i ordered it right away, Yolo
                          • #174544
                            pinballmagnetic
                              For any readers in the future:
                              The hosa cables fit nicely.
                              • #174566
                                  Glad to hear this!
