February 11, 2010 at 11:14 pm #106868krcassidMember
I am trying to connect my H8000FW to a new Lynx Aurora 16. It is unclear from Eventide manual what type of cable I need. Lynx said I need a "crossover" cable and that their end was Yamaha (not Tascam) pin-out. What is the pin-out on the H8000FW DB25, Yamaha or Tascam? Thanks!
February 11, 2010 at 11:43 pm #119989
The DB25 on the H8000FW uses the Tascam pinout and is designed to use a DigiDesign DigiSnake cable, which converts it to XLRs. It is not compatible with the Yamaha format.
To connect to another Tascam pinout you will need a crossover cable/adaptor, which connects the ins on one unit to the outs of the other, and vice versa.
February 11, 2010 at 11:52 pm #119990krcassidMember
Thanks! But, I still have options, right? I can have cable wired any way I want. Won't Tascam DB25 (on Eventide) to Yamaha DB25 (on Lynx) work?
Worst case, could I not use Tascam DB25 to AES XLR from Eventide to AESXLR to Yamaha for Lynx?
Thx for your help!
February 11, 2010 at 11:59 pm #131180
If you know what you are doing you certainly could make up a cable to connect between them – they are electrically the same, just use different pins.
Or, as you say, you could use two DB25-XLR snakes – this would be less tidy and more expensive, but would have unbeatable versatility.
February 12, 2010 at 12:08 am #131181krcassidMember
Cool. I don't have this expertise. But, the guys who are making the Mogami breakout cables for my Lynx do. However, you bring up an interesting point. Using 2 DSUB/XLR cables would allow me a bunch of flexibilty. Might be worth the extra cost. Thx!
March 3, 2010 at 12:07 am #131258philjochumMember
Essentially, you would need a 'Yamaha to ProTools' AES cable. That's how I have mine hooked up for live use.
Sometimes I wish I had a mult-to-fan on each end, though, to break out a channel or two one in a while. If you can afford the extra expense, I'd definitely buy the fan-out cables.
~Phil
