Home › Forums › Products › Stompboxes › Delay spillover in H9 Core
November 24, 2014 at 8:43 pm #112096
Marcelo Sa
MemberHow can I set delay spillover in H9 Core? When I change presets its cuts the sound!
November 24, 2014 at 9:26 pm #127020
H9 doesn't have Preset based Spillover, sorry! It has bypass Spillover, we call it DSP+BYPASS in the Bypass types.
November 28, 2019 at 7:04 pm #153348
Zsolt57
Participantwedelich wrote:H9 doesn't have Preset based Spillover, sorry! It has bypass Spillover, we call it DSP+BYPASS in the Bypass types.
Good Evening
This is an old thread, but I still would like to come back to it because of the bypass spill over. When I set the device to DSP + bypass then the decay tail will not be cut off immediately, but in half a second….
This still makes the whole thing useless. I am setting the bypass mode in the general settings of the device. I am aware that this is a global setting. Am I missing something?
Zsolt
November 24, 2014 at 10:34 pm #127023
Marcelo Sa
MemberThis is sad … this will never have this function?
So…Thank you!
August 7, 2015 at 7:44 pm #140058
scottykunkel23
MemberVery sad indeed.
I was just about sold to swtich from my strymon timeline but this kills the deal.
I play in a lot of live enviornments and it makes the pedal useless without this feature.
I use a midi controller to simultaniously switch presets on multiple pedals. Should we have to be expected to deactivate and activate the pedal between every song?
If you want to seem to appealing to your live market, this feature has to be included.
August 8, 2015 at 3:00 pm #140063
Emanuele Sereni
Participanthope to have soon a new software release to solve this issue.
August 10, 2015 at 4:55 pm #140090
spaceJam
MemberEmanuele Sereni wrote:hope to have soon a new software release to solve this issue.
I don’t think it’s an issue, or something that is going to be “solved”. It’s just something the Stompboxes don’t have, except by the Space, but sadly it doesn’t work when switching with MIDI.
I don’t know how difficult would be to code something like that but given the other complex things they have made, I don’t see it extremely complicated.
I’m still dreaming of someone who can do what Lexicon made with the Vortex 20 years ago.
August 10, 2015 at 9:12 pm #140103
scottykunkel23
MemberEventide,
I honestly need to know if you plan on adding the spillover feature or not. I need to be able to take it back to sweetwater in time if you aren’t planning on it.
Thanks for you speedy reply.
August 11, 2015 at 2:35 pm #140109scottykunkel23 wrote:
Eventide,
I honestly need to know if you plan on adding the spillover feature or not. I need to be able to take it back to sweetwater in time if you aren't planning on it.
Sorry, we will not be doing preset spillover on the H9. Hate to see you go! Just curious, have you considered using the H9 for other things that don't need preset spillover, like modulations, pitch effects, distortion, eq, pitch effects, etc?
November 30, 2019 at 3:36 am #153361Zsolt57 wrote:When I set the device to DSP + bypass then the decay tail will not be cut off immediately, but in half a second…. This still makes the whole thing useless. I am setting the bypass mode in the general settings of the device. I am aware that this is a global setting. Am I missing something? Zsolt
Did you mean DSP + FX Bypass?
My H9 works fine with DSP+FX bypass. I can hear the tail fading away. Have you tried some other algorithms with longer tails?
