Delay Time for TF
Home › Forums › Products › Stompboxes › Delay Time for TF
    • #108800
      Billy Foppiano
        I always like to set the delay to the BPM ..Used to be able to see what the time was set to by hitting the encoder once, but that doesn't work any more. How can we see what the current BPM is ?
        I work with a sequencer sometimes, so I need to hit the tap, and then fine tune it thru the encoder.
        Thank.
      • #123481
          If you are in play mode, just hit the right-hand switch once only.
        • #123490
          Billy Foppiano
            Thanks-My bad…a bad bogus entity was in my "Aux" menu, which blocked the BPM display.
            Thanks foryour quick reply. You guys are quickand wonnaful
