Delete supermodule from library
Home Forums Products Vsig and Preset Development Delete supermodule from library
    • #113477
      tlindaas
        How do I do it? I try to delete the supermodules I no longer need in my Eventide VSIG Windows XP folder, but they still show up in the supermodule menu.
        I use Vsig 2.4.9.
        Thanks,
        Torstein Lindaas
      • #143485
          You should be able to go to the vsigfile.exe that you are running, and in the same folder will be a folder called LIBRARY. Within this will be the supermodule file. Delete it.
          Alternatively, maybe this is what you are doing. If so, try renaming the LIBRARY folder and starting Vsig. If you still see the library supermodule, you may be looking in the wrong place.
