September 29, 2008 at 8:01 pm #105848
it only seems to happen on the "diatonic shifter 2" preset but when i edit and save and then recall my preset the shifters (set to unison and 5th, for example) come out fine for one note and then sort of go "subsonic" as if i had set both shifters down 10 octaves or something similar. no external modulation is set up…nothing to alter the intervals. just wondering if this is a known bug or if anybody else has this same issue. rebooting fixes the problem normally, but that's no good for live performances. software is 3.1
thanks.
-jim
September 29, 2008 at 8:06 pm #117893
Hi Jim
please update to latest OS V3.51.
I have never seen this. How are your settings and connections?
best
I
September 29, 2008 at 8:54 pm #117894
settings and connections? hmmm…pretty standard stuff. it's in a guitar rack, all unbalanced lines, everything's at 0 dB. not sure how these could affect a single preset yet not cause similar presets to do the same thing. i would guess it's an internal thing like a software glitch or an errant lfo misbehaving, but i'm just speculating.
as far as upgrading the software…well, frankly i'm too busy enjoying the eclipse ; ) but i know i should. could very well take care of the problem. i can always find a workaround like using "diatonic shift 4" since all my preset based on that algo work flawlessly. just curious if this was common or if i was the only one.
thanks.
-jim
September 29, 2008 at 9:36 pm #129051
Before torturing yourself, you might want to take Italo's advice and upgrade to the latest software.
For example, it has changes to the very preset that concerns you, which may very well fix the problem.
