Based on my research, it looks like more than one Eventide employee has given assurances that it should be safe to simply patch a 1/8″ mono to 1/4″ mono cable directly to the Space’s expression pedal input, in order to use assorted control voltage sources (e.g., an LFO from a Eurorack modular system), and that a range of -5V to 5V should be safe (although won’t produce changes under 0V and above 3.3V) because the Space is clipping the voltages to a 0V – 3.3V range.
I’m wondering if the same is true for the H9. Can you safely (1) use just a 1/8″ mono to 1/4″ mono cable, and (2) send voltages above and below the 0-3.3V range? I would of course attenuate to this 3V range wherever possible, but should I worry about damaging my H9 if when setting up a dense patch I might forget to attenuate the CV or accidentally knock the attenuator knob?
Thanks.
