Home › Forums › Products › Rackmount › Does H9000 run hot? Can it be sandwiched between other gear in a rack?
- This topic has 42 replies, 7 voices, and was last updated 1 year, 2 months ago by
Matthias Adloff.
April 4, 2020 at 12:11 pm #115850
Considering swapping out my DSP-7000 for the H9000, however the only readily accesible spot I have available would be sandwiching it underneath a Drawmer 1969 Compressor in my rack. Alternatively, I could move some things around and put it under a half rack unit (the OG overstayer compressor) to create a little more airflow above, however those are my only options if I want to have it within reach of my seating position. Which I do so that it’s easy to program. How hot does the H9000 run, is it a bad idea to have it underneath another piece of gear?
I’ve found my H9000 to run relatively cool (lots cooler than the H8000’s, as it has a fan), and the unit’s heat vents are on the side, anyway, so it seems to me it would be fine to have stuff on top or on the bottom.
That’s correct – the vents are on the sides so it’s a good idea to have some space on the sides of the unit, but having a piece of gear on top should be no problem.
April 4, 2020 at 10:41 pm #154509
Thanks guys. How’s the fan noise if this was right in front of me in prime listening spot? Assuming it’s hopefully pretty quiet?
April 7, 2020 at 6:59 am #154533KazRemark wrote:Thanks guys. How’s the fan noise if this was right in front of me in prime listening spot? Assuming it’s hopefully pretty quiet?
If your room is pretty much quiet you’ll hear it. Can’t say for sure if it would bother you or not but it isn’t silent.
April 7, 2020 at 4:38 pm #154540KazRemark wrote:Thanks guys. How’s the fan noise if this was right in front of me in prime listening spot? Assuming it’s hopefully pretty quiet?
when i got my H9000 i found the fan a little loud for me because it was right on my desk in front of me so I could control it from the front panel – I have super sensitive hearing though and the room is otherwise dead quiet
so after chatting with Eventide and support folk I was able to get to get the fan slowed down a bit which made a pleasing difference.
It’s now at the bottom of a rack with no sides on and lives below an Avalon U5 DI – I use Emote exclusively
My H9k is about 18months old now, no issues
April 8, 2020 at 9:10 am #154546macgee wrote:KazRemark wrote:Thanks guys. How’s the fan noise if this was right in front of me in prime listening spot? Assuming it’s hopefully pretty quiet?
I know it’s probably not an authorized mod and will void your warranty, etc, etc, but was it a software controlled command to adjust the speed or was it hardware/resistor type of modifications?
thanks
good point, i got it done by a company that is authorised in London based on feedback by Eventide – arranged through my dealer
but also, this might not be necessary as mine was an earlier unit and also the fan might not bother you – it’s just good to know if it does bother you you have options
April 8, 2020 at 1:24 pm #154548
Just wanted to add that we are planning to implement software control of the fan speed in the H9000. I can’t promise a date, because it will depend on when we can organize proper thermal testing, but I’d expect it to be before the end of the year.
This sounds good!
I’ve actually installed silent rack fans to keep my whole rack cool, so the H9000 fan might as well be dialled down a bit.
April 5, 2020 at 2:06 pm #154514
Not silent, but it seems pretty quiet to me.
April 7, 2020 at 9:11 am #154535
Thaqt’s how mine is positioned. Yes you can hear the fan noise, but I haven’t found it to be so loud that it’s distracting from editing/tweaking patches while music is playing.
Of course I have other vintage effects in the rack with louder fans (480L, IM-90), so for me it’s fine, but it will depend on your tolerance and what you are used to in your environment. If you have a dead quiet space, you might end up putting it down low or somewhere else and mainly using Emote.
August 24, 2020 at 6:13 pm #155613
Fan is loud enough to be a bit annoying for me too.
Would love to see fan speed addressed in new firmware!
August 30, 2020 at 7:34 am #155636
There are Noctua fans in that diameter that are virtually silent.
There is so much empty space in a H9000 that it provides excellent airflow.
If you have a pro rack with active cooling it is more than enough.
Compared to an UAD Apollo or TubeOpto preamp it runs totally cool.
But the sound of the stock fans is comparable to a standard desktop PC…
Its not something you want on the table in front of you
Having just spent a small fortune on this unit, I’m not keen to void my warranty.
Would prefer a fan control in firmware, but if I were to for example modify my unit, what would I need to do?
Is the Noctua a plug and play kinda connection to the motherboard?
The fan is a bit of a downer for an otherwise lovely device!
We chose the H9000’s fan mainly for its quietness. I wish my home office were quiet enough to hear it!
Adding fan speed control to the firmware is something we’ve been meaning to do for ages, but it kept getting pushed down the priority list. However, since you and others have brought it up, I’ll see if I can get this done in the coming weeks, after the current beta is out.
I don’t know the specific fan you are talking about, and I’d hesitate to recommend modifying the H9000 yourself.
Can you modify the H9000 with a Noctua fan prior to the H9000 leaving your factory?
August 31, 2020 at 9:05 am #155640
I imagine that the amount of heat generated (and therefore cooling required) will also depend on how many expansion cards are installed in the H9000. For those of us with stock 9000’s and no expansion cards, a lower fan speed may be fine. People with fully loaded 9000’s may need the maximum amount of cooling possible. That’s why I agree with drxcm and hope Eventide can provide fan speed management via the OS.
(FWIW, I have installed quieter Noctua and similar fans in various older effects in the past and it’s been fine, but my use of the gear and how I have it racked may not be the same as you).
September 4, 2020 at 9:17 am #155701
I guess the question I’d have is — if possible, can you post the fan’s manufacturer/model number so we can at least look at the current specifications without having to open up a 9000 ourselves?
Here is the datasheet, so if you wanted to install a different fan yourself, you have the information you need. This should not be construed as a recommendation to do so.
Our fan is rated 14.3 dBA, which, according to Noctua’s specs at https://noctua.at/en/products/fan, is quieter than all their 80mm fans with PWM. (However, making absolute measurements of acoustical levels is very dependent on setup/calibration).
Yesterday I did some work to enable the PWM controller on the H9000 and found that reducing the speed makes a big difference to the noise, while keeping the temperature of the DSPs at a reasonable level, at least in my home office environment. This will get released soon, after we do a lot of testing to make sure we won’t overheat.
September 4, 2020 at 11:40 am #155703
Thanks. That’s kind of what I have found out when doing work on old effects units. The specifications of the fan are only part of the story. How it’s mounted, the layout of cards and components inside the unit, the overall airflow through the unit, they all contribute to the perceived noise.
I appreciate the spec sheet and I will keep the screwdriver away from my H9000 and wait for the OS update. 🙂
September 4, 2020 at 4:39 pm #155705
Awesome support from jbamberg!
Thanks so much for the quick
responses, updates and datasheet.Really looking forward to trying the firmware out when it hits!
October 1, 2020 at 5:25 pm #155943
So I have a follow up question about the H9000 in a rack.
I currently have my H9000R in a 3u rack, with nothing above (open space), however…the width of the H9000 (It is quite wide) does not allow for much open space on the sides of the unit where the fan is.
I would estimate there is *maybe* 1/16th of an inch between the sides of the H9000 and the sides of the rack case. I looked at another case I have by a different vendor, and if the H9000 was mounted in that case, the clearance on the sides would be the same. When I feel the top of the unit on the side where the fan is…it does feel pretty warm to the touch…but not any hotter than the Cisco switch I am using (which does not have a fan). I do have a Dante card installed in the first expansion slot (the slot closest to the side of the unit).
Is this OK? I saw where Eventide recommended some clearance on the sides…but I don’t see how to make this happen unless I was to cut a hole in the side of the rack…which sort of negates the protection the rack would provide.
Thanks in advance.
October 9, 2020 at 1:07 pm #155991
I cut a hole in both sides of the rack to allow cross-ventilation. The unit is much cooler now. There just was no way around it if I was going to keep the unit in a commercial, standard, non-custom rack.
However, I am still awaiting an answer from Support on the thermal tolerances of the unit. Is it actually safe to have it in a rack with effectively zero side clearance for ventilation? If the answer is ‘no’….what portable racks do they recommend? I have racks by two different manufacturers here…and both are designed so that there would be very little clearance. Likewise…the traditional plywood-type road cases would effectively block the air intake / exit holes as well. If the unit MUST be racked in a padded case that has extra clearance on the sides….this kind of info should be in the manual. There is no thermal info in the manual I can find…and the only mention of ‘temperature’ I can locate is a disclaimer that the unit will not be covered under warranty if ‘exposed’ to dangerously high temperatures. If the unit ‘generates’ excessive temperatures due to ventilation, and fails accordingly, is it not covered under warranty? Sorry to be pedantic with the questions…but it would be helpful to get some real answers. Thanks!
October 15, 2020 at 2:21 pm #156021
Hello? Mic check. Is this thing on?
Still waiting for an answer from Eventide.
Yes, it’s on.
The short answer is that there is no specific guidance on thermal limits, nor is there any thermal cut-out in the event of overheating. We selected the case, fan and heatsink design to cope with most conditions we would anticipate for a rack unit. I realize that’s vague, so we have been working on a more rigorous solution.
The new beta (1.3) is able to monitor the temperature of the DSPs. However, we still need to implement a thermal fail-safe mechanism. We are also planning to use the same mechanism to regulate the fan speed to make it quieter in less adverse conditions. These features will be rolled out after 1.3 hits production.
Yes, it’s on.
Thank you for the honest and forthright reply. I understand the reason behind the imprecise answer, and it is nonetheless much appreciated. It would be helpful if the release documentation for 1.3 includes some guidelines as to safe operating temperatures for the DSP, since we will be able to monitor DSP thermals.
Hope you understand….I love my baby…and don’t want to put her at risk!
Thank you again
August 20, 2021 at 2:49 am #158434
Is there any update on the future ability to throttle the fan? For my work the H9K is too loud to put in a desktop rack but that is ideally where I would like to put it for easier access. I spend a fair amount of computer off time during creation so emote + distant rack is not really a solution all of the time. Thanks for any info!
Sorry, no updates to provide at this time. We do realize that this is something that could be useful and I’ve bumped it up on the priority list, but I can’t provide any timeline for when this may be added. Thanks for your patience.
August 24, 2021 at 10:50 am #158454
Throttling would be great. In my ACed studio, the H9000R is always somewhat cool (sic!), unlike all it’s predecessors. Just LOUD.
September 2, 2021 at 8:06 am #158503
This is why I went for the Dante expansion.
The fan noise is too great for me to be able to have it in the machine room.
My H9000 sits in the adjoining room with a pair of ethernet cables to the switch.
I would rather have it in the control room but this is an acceptable compromise.
October 25, 2022 at 10:33 pm #166069
I can’t rack anything underneath the H9000, because it came with rubber feet installed which prevent the rack holes from lining up.
Seriously? How can I remove these feet?
You must be logged in to view attached files.-
October 31, 2022 at 1:07 pm #166146
The rubber feet should come off easily with a knife or razor blade.
October 31, 2022 at 12:54 pm #166144
Mine came with the feet in a bag ready to be stuck on. Did not as I knew I would rack it. Can’t you peel them off?
November 29, 2023 at 3:12 pm #176313
Thank you for adding fan speed control in the latest firmware!!! this is huge. I feel like I was often not turning it on just because of the chassis noise, especially since moving to a new Mac Pro which makes my control room incredibly quiet now.
December 5, 2023 at 7:41 pm #176543
I too have a dead quiet Mac Pro and room in general.. how noticeable is the H9k noise now with the new firmware?
December 6, 2023 at 12:59 pm #176558
I would say barely noticeable at all and I am sensitive to these things. major improvement. I have moved it to just to the left of me on top of a desk… and if I focus on it, I can just barely make out a sound. I think if I moved it to a rack under the desk I wouldn’t hear it at all but I don’t think that’s necessary. It did use to be under the desk and I could still hear the fan pretty considerably. When I put my ears to both, I would say the sound of the H9K is comparable now to the very quiet noise of the Mac Pro, perhaps the frequency of the H9K is a tad higher.
December 6, 2023 at 2:01 pm #176568
That’s fantastic news! Currently i have a mac pro and Avid S6 in the room and it’s creepily quiet.. the actual loudest thing in the room is the power supply inside my Nord keyboard when it’s on.. glad to hear the H9000 at this point can be at the Mac Pro level..
December 8, 2023 at 12:26 pm #176618
I hope we get the option so we also can choose a faster fanspeed too – the better cooling the electronics last longer
I did this for my TC M5000, i measure output wind close to 30 celsius now
sorry for my english
December 14, 2023 at 8:32 am #176764
Sorry, this is not possible. The default fan speed of the H9000 is the fastest that it can operate. This cools the H9000 very well and it will last a long time.
September 18, 2024 at 6:06 am #184820
The fan keeps being loud. Very loud, not only because of air flow but also because of a small ,yet noticeable amount of rattling and vibrating. I do not see any difference when toggling the fan control in Emote. Booting from cold in a cool environment (~10° Celsius) the fan spins up to its maximum speed and remains there, regardless of what I set in Emote.
Any way to read out the internal temperature? A faulty thermal sensor? I mean, I could just add a resistor to the fan, but I do not want to destroy myH9000R.
September 18, 2024 at 10:20 am #184824
Can you please email support@eventideaudio.com with a video that demonstrates the noise you are hearing? Can you also toggle the fan speeds during this video? It should be noticeable that the fan speed is changing when you toggle this setting.
September 26, 2024 at 9:55 am #184943
Done. Please note that this has absolutely no priority, since I usually have the H9000R in a closed server rack.
