Does the H90 needs to be active to have the inserts available?
Home › Forums › Products › Stompboxes › Does the H90 needs to be active to have the inserts available?
    • #172518
      lander4002
        I have all my tone pedals in the insert 3 so I can place them anywhere in the effects chain. The problem is that I need to active the H90 and then bypass the algorithms one by one in order to have my distorsions available, if I bypass the program my inserts are off and I dont have access to them.
        Is there a way to have my inserts on all the time?
      • #172519
        joecozzi
          Presently, there is not a way to maintain active inserts while the Program is bypassed. As you stated, the way around this is bypassing the individual presets within the program. To make it easier, it’s possible to map both preset act/byp commands to an external aux switch to control states simultaneously.
        • #172520
          lander4002
            Thanks for the answer!
            It will be great knews if you develope an update to solve this issue.
