Home › Forums › Products › Stompboxes › Does the Time Factor quantize loop length to external MIDI clock?
June 21, 2014 at 11:13 am #111726allochthonMember
This has been asked by another poster four years ago, but they never received a response. It is not addressed anywhere in the manual of in the FAQ. Seems like a pretty simple question…
Does the loop length quantize to match an external MIDI clock????
June 21, 2014 at 3:50 pm #126177
The current one does not. But we're working on it for the next version – this is one reason why it is delayed.
Less anyone misunderstand this, the tracking will not handle tempo changes – for example it will not time-compress the loop if you speed up the tempo – it will instead cut a bit off the end.
June 24, 2014 at 7:52 pm #126202onlinemusicParticipant
This is a critical feature for many modern styles of production. Thank you for working on it.
June 24, 2014 at 8:05 pm #136865entreat69Participant
Sooo looking forward to the much anticipated eventual release of the FW update for Time Factor.
April 3, 2018 at 6:40 pm #148876onlinemusicParticipant
Does anyone know if this feature was ever implemented? Thanks!
April 4, 2018 at 1:03 pm #148881brockParticipantallochthon wrote:… Does the loop length quantize to match an external MIDI clock????onlinemusic wrote:… Does anyone know if this feature was ever implemented? Thanks!
I believe this is what you’re looking for, from the updated Looper manual:
https://com-eventide-drupaluserfiles.s3.amazonaws.com/download/file/Looper.pdf
Manuel Looper wrote:Tempo Mode Footswitch QuantizationMIDICLK is made up of a series 24 “ticks” per beat. Tempo Mode quantizes many of the Footswitch actions either to the next MIDI beat or the next MIDI tick. The quantization action of the Footswitches for each Looper State is as follows:
Empty ● – Starting a new recording syncs to the next beat ONLY if in MIDICLK Slave mode AFTER having received a MIDI Start command. Otherwise, this begins recording on the next tick. ►– No action. ■ – Only used for tap tempo
Recording ● – Record to Dub transition quantizes to the next beat. ► – Record to Play transition quantizes to the next beat. ■ – End recording and stop, quantized to the next beat
Dubbing ● – Dubbing in/out doesn’t do any footswitch action quantization. ► – End Dubbing and Start Playing from Loop Start. This action quantizes to the next tick. ■ – End Dubbing and Stop Playing. This action quantizes to the next beat.
Playing ● – Start Dubbing, no footswitch quantization. ► – Start Playing from Loop Start. This action quantizes to the next tick. ■ – Stop Playing. This action quantizes to the next beat.
Stopped ● – Starting a new recording quantizes to the next beat ONLY if in MIDICLK Slave mode AFTER having received a MIDI Start command. Otherwise, this begins recording on the next tick. ► – Start Playing from Loop Start. This action quantizes to the next tick. ■ – No action.
April 4, 2018 at 11:27 pm #148883onlinemusicParticipant
Great, thanks!
