Does the TimeFactor sum the inputs on mono output even when bypassed?
Home › Forums › Products › Stompboxes › Does the TimeFactor sum the inputs on mono output even when bypassed?
    • #107879
      I would like to know what happens when the Timefactor (set on mono output) is fed with stereo inputs and is on bypass. Does it sum the inputs? I have another stereo delay in front of the TimeFactor and I want to know how to set things up on the occasions I have to go mono. Thanks!
    • #122206
      MarcoR
        I would like to know this too. Actually, I'm interested in left/right out of the timefactor into left/right  space then mono out space. The reason is to achieve series parallel path where I send a dry signal to space to be processed with reverb but the wet delay is summed in the output; the goal being not to apply reverb to the delay.
      • #122752
        javiceres
          I think it sums the incoming signals, it's probably in the manual.
