Don’t tell me I need to be connected to internet to run H9 control software
Home Forums Products Stompboxes Don’t tell me I need to be connected to internet to run H9 control software
    • #112415
      4johnny
      I registered and updated my H9 on a PC connected to the internet.  I then moved my H9 down to my studio PC which is not connected to the internet.  When I try to run the H9 control software it won't let me unless i connect to the internet.  Please don't tell me I need to be connected to internet to run H9 control software.
    • #127623
      gkellum
      You need to be connected to the internet to register your H9. After you register it, H9 Control saves the key that it gets from our server that it needs to talk to the H9 to a settings file which on Windows is under C:/Users/your-user-name/AppData/Roaming/H9 Control/h9_settings.properties.  (AppData is a hidden directory; you'll need to adjust the settings of Windows Explorer to see it.)  You can copy this file onto a USB drive and put it at the same location on your PC not connected to the internet and H9 Control will work fine.  You'll need to have v2.1.1 (or higher) installed on your Windows PC that's not connected to the internet for this to work.
    • #138529
      4johnny
      Good news, Thank you!
