Dry Wet issue in Pro Tools
Home Forums Products Rackmount Dry Wet issue in Pro Tools
    • #116339
      petergregson
        I’ve got an H9000 which I love, but having a really simple issue with routing. Maybe it’s just how I’m approaching it but I wonder if anyone can advise:
        Basically, I want to be able to have 4 stereo audio tracks bussing to 4 instances (ADAT) to only print the wet mix from the H9000.
        Every which way I try to achieve this, I end up printing the dry signal as well: I really just need to be able to do this for stems sending back and forth to an engineer I work with who doesn’t have an H9000 so I want to print as audio all the time rather than having a Dry/Wet mix on the HW insert on each track I’m wanting to treat.. None of these issues exist with my various Hardware reverbs / FX, so I’m going slightly mad trying to figure out how and why this should be any different … and yes, all the appropriate settings in Emote are set to 100% wet!
        Any thoughts from anyone?
        enlightened
      • #157094
          Could you give some more information about how you have things routed both in Pro Tools and Emote?
          If you could provide some screenshots that would be useful as well.
